ESA 42" plasma will not turn on
Turn on the on/off awitch and the red standby light lites, then push the on button on the remote control and yoou hear a relay click, the stand by light goes out, then you hear a softer click, then nothing. Yu can start the cycy\le again by un-pluggung the tv.
Find a power supply that was the problem with my. Exept my tv now dont have picture Cause ysus board is dead..
Posted on Jan 31, 2009
Hitaci plasma 42hdt20 remote will turn monater when red standby light on
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Dec 25, 2016 | Hitachi 42HDT20 42 in. Plasma Television
Tv turns on but stays on standby
Have you checked the manual? Here is a link
May 15, 2016 | Hitachi 42HDS69 42 in. Plasma Television
Standby light changes from red to green
hi this fault could be down to capacitor in the power supply, they bulge or go leaky, you need to take the back off the tv, to have a look. try and find a tv tech in your area hope it helps
Jan 05, 2014 | LG 42PX5D 42 in. Plasma HDTV
Wont power on
some tv's always have standby light on, even iff you turn off by tv button. solution 1: with light on, press a number on remote. solution 2: with light on press stand-by button on remote. solution 3: with light on push the 'on' button on the tv set. solution 4: unplug tv set, wait a few seconds then plug back in, if no light then turn on tv using button on the set, and then channel number.
Jun 25, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
42" plasma worked fine this
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Sep 15, 2011 | LG 42PC3D 42 in. Plasma Television
Have red light tv won't turn on
I have a post about this, go find it. It's about cleaning the back of the tv. Good luck.
Jul 29, 2010 | Hitachi 42HDS69 42 in. Plasma Television
ESA 42" plasma tv not turning on
I have a 42 inch plasma and I was watching tv last night on it and suddenly it turned off on it's own. I tried turning it off and on and nothing happened. Then I tried to unplug it and replug it and nothing. My remote does not work either. Anyone know what exactly happened? Did my screen blow or what? I hardly ever use the tv and I only had it on from 8:30 p.m. - 10:20 p.m. and it turned off. All the other tv's in my house worked fine - I checked them. Also, my dvd player and cable box is on the same power cord and both of them work. Any solutions or help would be most appreciated!!! Does it just need to cool down or did I burn something out? Help!!!
Mar 16, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
331 people viewed this question
Top Televison & Video Experts
