i can not recommend you to replace another bult, use the manufacturer specification, you can have problem with fuse, wires. use the exact bulb. God bless you
just the bulb.. write down the model number of the unit and they will give you the same bulb that you need, just give them the model number.
If you are going to install the bulb just remember DO NOT HOLD directly the bulb, use any clothe or gloves, because even a fingerprint can busted the bulb even thou it's not yet use
You should be a panel on the inside ofyour trunk to be able to pull the bulb out in there. Are you can go to most autoparts stores, and they will change them out for You.
Have work on these model, but narmaly they should be easy, to help, unplug it and open the cover to see if you can figure it out better, narmaly it's a clip on stage plastic that hold it in place, The bult could have purchse I think true gooles, with there part # back track it to see if a local shop would have it. $30 was very high.
