Question about Minuteman Enterprise E 750 (90000568) UPS System
Can I change batteries without unplugging unit?
    Problem Solver:
  • 14 Answers
Yes...but make sure the unit is turned off...completely...
Posted on Jul 07, 2009
Wont come on without the charger cable
Sounds like you have a dead battery problem. Unless I'm mistaken, these have internal lithium ion batteries that you can't change without taking the unit apart. You might have to take it in to have it serviced.
Mar 29, 2014 | Eclipse Touch 2.8V 4GB* Video MP3 Player
Screen goes black when unplugged
update bios check battery at conection try using unit without the battery and then with battery some batterys are just not good for long I would change battery but before you do that check and update the acpi, battery driver in device manager
Mar 01, 2013 | Everex StepNote SA2053T Notebook
Resetting the panasonic tde600 password without losing programming
If it contains a CPU, and I assuming it "does," it should have a small batttery to run it "inside" the unit. Unplug your unit before taking it apart and search for it. I should be a round battery. Programming in just about any electronics is run by EPROMS. Passwords are run by CPU's.
Sep 12, 2012 | Panasonic KXTDE600 KX-TDE600 KX TDE600...
Kidde smoke detector without a door or tab for back up battery - where do I find the battery so I can change it. It has been beeping for close to 39 hours. Installer did not leave a users manual. (The...
Some smoke detectors are AC-only, so there is no battery. Dual-power units typically have the battery compartment on the back of the unit, where it attaches to the wall or ceiling.
Most units must be removed from their mounting bracket to change the battery, as the battery cover is on the back.
You rotate the unit about 1/2 turn counter clockwise, and it should come off the wall/ceiling. If it has an AC power connection, you unplug that so you can change the battery more easily.
Oct 16, 2009 | Home Security
My ibm lenovo laptop is plugged in into the AC power, it shows that the battery is charging but when i press the power button so the computer could start up, it won't power on. i removed the battery and...
Had a gateway laptop that had similar issues. 1. Has the unit ever overheated ? . if so you may have to open the case down to the battery, hopefully the unit has a plug in style battery, when you unplug it and wait 30seconds, then plug it back in you will reset the bios on the unit. I was about to junk my 6 month old computer until i tried this step. put it back together... every thing resumed as normal didnt lose or change a thing. hope this helps
Aug 25, 2009 | Lenovo ThinkPad SL500 Notebook
Change Batteries in Pronto M91 with swivel seat.
Turned out to be a "doh!" moment. Use the lever on the side of the seat to permit swivel. Unplug Controls connector. Lift seat off unit. Remove battery compartment cover by loosening 2 Philips-head screws on the Charger cover at the rear. Disconnect cable to Electronic Controller at front of front battery. Disconnect the Red and Black battery connectors, the ones that join the 2 batteries. Lift out batteries. Transfer battery connections to new batteries. Reverse the above process to reassemble.
Solved this without any help from outsiders, including FixYa, who wanted to charge me for the solution.
Jun 12, 2009 | Invacare Supply Group Invacare Pronto M91...
IPaq rx3115 working like PC not Pocket PC, need to plugin always
You need to purchase a new removable battery for your RX
The removable batts usually only last about a year (like cell phone batteries).
Although it is showing 100% charge, the battery is not storing enough power to run the ipaq
The rx series uses 2 batteries, one is the removable one u can see/access when u remove the back cover. The other batt is a small round batt which stores the basic info for your system (so you don't lose your data when u swap out the removable battery).
This small (backup) batt is similar to the cmos battery on a laptop or pc.
You cannot easily replace this, as the unit needs to be disassembled to access this batt.
If you are tech-y (and brave), the replacement button batteries are sold on ebay for $9-12
Normally, if your removable batt is bad, you could still use your unit plugged in, and could
remove from AC power without losing data. Not the case if your replaceable batt is exhausted.
When both batteries are bad, you lose everything when u remove unit from AC power.
My workaround without having to disassemble unit:
Purchase and fully charge new removable batt (They have huge capacity ones available for like $15 - better than the original !).
Load up all your programs & settings the way you like.
Perform full backup to SD card (& also on PC via active sync - to be safe)
Now the only time you should lose your data (like hard reset) is if you allow the battery
to completely drain, in which case you can restore your backup.
If you purchase 2 removable batts, you can easily swapout without losing data if you
use the usb charge cable & leave ipaq plugged in while you change battery
Hope this helps
Jun 01, 2009 | HP iPAQ RX3115 Pocket PC
It want switch on
My Compaq Armada 110 does the same thing from time to time. Most of the time, the best way to have it power back on:
Unplug it. Pull the battery out. Plug it back in without the battery. if you get a light flashing to the left of the top section above the keyboard, you're set. put the battery back in and power it on. if still no flashing light then next:
unplug the unit, pull the battery, flip the unit upsidedown and open the panel with the two screws to the right. reseat the memory modules in the sockets there. then reassemble, the plug the unit in without the battery. if you see the light, then put the battery back in and you're set. power it on.
if it still doesn't power on, i've got other suggestions but these are the main things I have to do to get mine working. :)
Nov 26, 2008 | Compaq Armada 110 Notebook
Compaq presario c-300 charging system
that is normal.. you can change that dim setting to power option in control panel.. it really dim when unplug.. but you can change that if you want, so it will not dim.
Dec 26, 2007 | Compaq Presario R3000 Notebook
Minuteman Enterprise E 750 (90000568) UPS System Logo
35 people viewed this question
Top Minuteman Computers & Internet Experts
Larry Chandler
Marvin
Marvin
Joseph Hoffmann
Are you a Minuteman Computer and Internet Expert? Answer questions, earn points and help others
