Question about Sylvania DVR90VE DVD Recorder/VCR
Recording #1-I bought the wrong type of disks, I have +R/+ RW#2-I don't have the instruction manual. (Can I get the intruction manual online somewhere)?#3-After I thought I had recorded a dvd, the on-screen msg said the disk didn't have playback ability#4-when I push the "setup" button, the box to the right of it says "disk" but I can't get over to that. What button do I push to toggle to that choice? I will go buy the -R disks tomorrow and try them but what other advice can you give me on dubbibg from VHS to DVD?
  • 4 Answers
Re: Recording
You need to buy the - disks. (+ will not work).
The instruction manual can be found online.
Posted on Jul 22, 2008
0 characters
3 Points
It's not reading cd, or DVD
Check for scratches on the disk surface - these can inhibit the player from reading a disk correctly.
Some players will read olny certain type(s) of disks. This is an issue mostly for disks created on a computer, not those that are prerecorded and available for purchase or rental that contain movies and music.
As stated above, dIsks created on a home computer may not always be readable on a home player. Re-writeable and recordable types that are not listed as being compatible will not work. Check your manual to see which types are acceptable and not. DVD types are: DVD-R, DVD-RW, DVD+R, DVD+RW and DVD-RAM CD Types are CD-R, CD+R and CR-RW. Older home CD and DVD players generally work with "-R" types and the newer players with both "-R" & "+R" types. "-RW" and "-RAM" types are the least likely to be readable in home players.
Additionally, most players require that disks created on a home computer be "finalized". This is an extra step that isn't required by most CD / DVD drives in computers. Just because it works in your computer doesn't mean it will work in your home player. If you're using compatible media and still not able to read disks, check your CD / DVD recording software options to enable finalization.
Jan 03, 2013 | DVD & Blu-Ray Players
I just bought the zv427mg9 a and I can not get it to pause recording when recording from vhs to dvd. Can you help?
the magnavox ZV427MG9 vhs to disc dub recording can not
be paused. you can not pause and start dub recording in this
mode. you must let it run start to finish . It also states this
in the manual which disspointing....
For this type of recorder it should be able
to do just that, pause while dub recording whs to disc, but it
Aug 22, 2010 | Philips Magnavox DVD+R/+RW Recorder/VCR
DVD player will not read any discs.
> I tried recording a VHS to a DVD according to the instructions in the manual.
There can hardly be instructions in the manual to do this since that model is not a DV Recorder, but if it isn't reading any DVD then you have a warranty problem assuming your unit is still within the warranty period.
That unit is capable of recording DVD content to VHS tape but not the opposite.
Mar 13, 2010 | GoVideo DV2130 DVD Player/VCR
Recording error
Refer to your user manual for error codes and troubleshooting tips.
If you cant find the error code then please kindly forward the following:
Disk Type:
Recording Device:
Hardeware Specifications:
May 26, 2009 | Symphonic SR90VE
Recording Error -- E7
When I bought my emerson ewr10d4 about 2-3 years ago, the machine only recorded on disks that were rated at 2x or 4x speed. And it didn't accept off-brand disks, it only liked the major brands like Maxell, TDK, Memorex, Sony. I learned this quirk the hard way. Eventually, when I called the 1-800 number, they sent me a disk to upgrade the recorder to 8x speed (and it was very simple to do - basically just pop it in). Helped a lot, although this year most disks in stores are 16x speed, and as of a couple months ago (November 2008) emerson didn't have a newer up-to-date upgrade available. But if you didn't do the 8x upgrade yet, call them and start there. It's a small improvement, but an improvement nonetheless. By the way, if anyone wants to buy some lesser-known chinese and japanese-brand disks, I may be able to help!
Dec 28, 2008 | Emerson EWR10D4 DVD Recorder
Says blank DVD-RW is not formatted, then formats -- then error
I have same TOSHIBA D-VR4XSU VCR/DVD RECORDER. According to the
manual, you (COULD) can use for recording: DVD-RAM, DVD-RW and DVD-R (see page 50). WRONG!!! I bought all 3 types of discs, but after few
weeks I got same experience you got now. Just type DVD-R works. The other
types were - wasted money and a lot of time trying to finalize the disc. I had to
throw all into the garbage. Try DVD-R and you should?? be O.K.
Dec 13, 2008 | Toshiba DR4 DVD Recorder
Copy recorded pgms off DVD HDD to DVD+RW
the manual specifies that if you select for recording the FR mode the machine automatically adjusts the recording mode for the program to fit on a 4.7G dvd. If you use a dvd DL if will auto detect that you have this type of dvd and the FR mode will automatically allow you to make full use of the available space. Depending on the space needed on the dvd the picture quality will be good to excellent (refer in the manual to Recording Modes..)
Aug 30, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Failure to record
I had the same problem on my Philips 3400. Changing media worked. Try RW media if R does not work.
Dec 01, 2007 | Philips DVDR3390/37 DVD Recorder
Cannot play this disc
The DVD-R130 can only record to DVD-R and DVD-RW disks - it cannot identify blank DVD+R and DVD+RW disks. For recorded DVD disks, the player will play finalised DVD+R/+RW disks without any problem.
May 06, 2007 | Samsung DVD-R130 DVD Recorder
Sylvania DVR90VE DVD Recorder/VCR Logo
74 people viewed this question
Top Sylvania DVD & Blu-Ray Players Experts
Are you a Sylvania DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
