Question about IBM Lenovo ThinkCentre M55e PC Desktop
IBM Lenovo doesnt start. Fans are ok Ram and Graphics card attached with the system is ok( I checkd with another system). The led on front , the keyboard leds and cd driv leds turns on as soon as I press the power button. but goes off after 2 or 3 seconds. the power button remains on. Please help me
    Problem Solver:
  • 16 Answers
Sounds like your graphics card and display are not properly communicating. If the card doesn't sent out a signal to the display, you will see nothing on the screen. Did you check the graphics card on another machine using the same display? If so, something different may be wrong. I am assuming your display is powered on and plugged in properly. If there is more than one video connector on the machine, you may have it plugged into the inactive video connector. If all of this checks out I suspect you have some hardware problem with the system unit.
Posted on Jul 03, 2009
Won't turn on,Front led on,fans OK,and RJ45 led on.
fan working? cd rom drawer open and close? power on led working. hard drive spinning?
Oct 09, 2016 | IBM Lenovo ThinkCentre® M51 (814339U) PC...
Will a DDR3 graphic card work as it should work on a DDR2 motherboard or ram
Add more RAM
If you're not sure if a module is right for your system, use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system.
You should always ask for a guarantee on the compatibilitybefore making any purchase and try to buy for working pairs if possible.
computer users often get confused when assembling or upgrading their first computer. While the most common error is made when distinguishing system memory, RAM, from hard drive space, gaming computers have an extra wrinkle to worry about.
Graphics cards use memory separately from the system memory mounted on the motherboard. Some graphics cards use the more typical DDR standard, though it's permanently attached to the graphics card circuitboard, while others use the new GDDR standard.
For the most part, the internals of the graphics card aren't relevant to the rest of the computer it's all about the connection slot.What Is DDR Memory?
DDR, or "Double Data Rate," is the standardized random access memory format for most desktop and laptop computers.
DDR RAM comes in different generational standards: DDR, DDR2, DDR3 and the newer DDR4.
RAM chips, known as DIMMs, come in only one format, as do the DIMM slots on motherboards, so a DDR3-compatible motherboard memory slot can accept only DDR3 RAM DIMMs RAM that uses an earlier or later standard is incompatible.
GDDR Memory and Graphics Cards
Modern graphics cards use a modified memory standard called GDDR, short for Graphics Double Data Rate. While similar, GDDR and DDR memory is not the same:
Most importantly, GDDR memory is integrated into the graphics card and cannot be removed. Some older graphics cards use DDR, DDR2 and DDR3 memory, but this is also integrated into the card.
Graphics cards of varying power come with different kinds of RAM as of the date of publication, most cards feature GDDR4 or GDDR5 memory
Graphics Card Motherboard Connections
Discrete desktop graphics cards are mounted inside a computer case and plugged directly into the motherboard.
Three standard connections are used for graphics cards: PCI-Express (the most common and powerful), PCI and AGP.
It is this connection that determines how much data can be shared between the graphics card and the other system components, such as the CPU, the system RAM and the hard drive.
The expansion slot standard is the primary function for determining whether or not a graphics card is compatible with any given computer:
If your motherboard has a PCI-E slot, it's compatible, if not ideally so, with all PCI-E graphics cards.
Graphics Card Memory and System Memory Compatability
Memory is an important part of game performance, but graphics memory and system memory are two different things.
For better performance, it's best to have as much graphics memory AND system memory as possible, but the different standards used by the graphics card and the motherboard are largely irrelevant.
As long as the graphics card uses the correct expansion slot standard, it will work with the corresponding motherboard, regardless of its DDR version.
Mar 10, 2014 | IBM Lenovo ThinkCentre M55e PC Desktop
I have 9600 gt Graphics Card on Intel DG31PR with dual core processors & 2 GB Ram. While I starting My PC after 2-3 days then PC started but there will no display at all, hdd led not blink but pw led...
It's the motherboard, the BIOS forgets that there are components attached to the board and can't detect them.
Time for a new motherboard, this one is unfixable and it you wait too long it will fail while you use it with who know what consequences.
Oct 04, 2010 | Intel DG31PR Motherboard
Lenovo 3000 y410 graphic card upgrade?
Lenovo Y410 System RAM can handle up to 2GB of memory. Since the machine has 2 slots for RAM and you already have 1GB preinstalled with the computer all you need to purchase is another stick of 1GB RAM.
There is no chance of upgrading Graphics card since it doesnt have a video card slot and the preinstalled VCARD is onboard.
Should you have any other questions just please leave a comment.
Cheers~
Jul 14, 2010 | Lenovo 3000 Y410 Notebook
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
IBM THINKCENTRE A51 - WON'T BOOT
Simple dear, I think that you can see the power led and hdd led but it wont boot. Right. So switch the system and than open the cabinet and than remove the RAM , CLEAR THE DUST ON THE SLOT AND RAM. THAN REPLUG IT IN THE SAME WAY. PLEASE DO NOT INSERT IT FORCEFULLY BECAUSE IT WILL GO EASILY IF YOU ARE INSERTING IT IN RIGHT WAY. SO CHECK THE POSITON OF THE NOTCH ON BOTH THE RAM AND SLOT OK
AND THAN START THE SYSTEM. THIS MIGHT DEFINATELY SOLVE YOUR PROBLEM.
Nov 19, 2008 | IBM ThinkCentre A51 PC Desktop
No video output
Do you get a single beep from the POST at start-up? That signifies that the internal check is OK.
Jun 27, 2008 | Computers & Internet
Graphics
Graphics cards on laptops cannot be changed or upgraded. In order to do this, I believe you have to change out the screen, because graphics cards in laptops are within the screens.
May 22, 2008 | IBM ThinkPad G40 Notebook
Graphics card locks up after 1-2 mins of running a game
Sounds more like a over heating or RAM problem. Try pulling out and re-inserting the RAM. Make sure that the fans are running and clean.
If it doesnt lockup in safe mode, try upgrading the video drivers...
Jan 13, 2008 | Computers & Internet
IBM Lenovo ThinkCentre M55e  PC Desktop Logo
277 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
