Question about Nikon Coolpix S210 Digital Camera
The battery will not charge when I plug it into the computer. It is completely dead, black screen. Thanks
    President:
  • 423 Answers
The S210 does not charge the battery via a USB connection. You need to take the battery out of the camera and charge it with the charger that came with the camera. If you don't have the original charger, there are several replacements on the market.
Posted on Jul 03, 2009
I have an Hp pavilion ze 4800 and think that the battery is completely dead how can I tell for sure'
Pull the AC plug. If it's more the 4 years, I would say it's done. A battery has a Cycle limit, charge/discharge. Be sure to shop for a quality battery, stay clear of cheap batterys, they often don't work well with your laptop. If you have a multimeter you can verify, but if it will not charge or hold a charge, it's most likely time to replace.
Dec 06, 2012 | Computers & Internet
Got a black screen when i switched on and battery light is orange for a few seconds then goes off
You battery is probably Dead , is it plugged in to the wall ? If its not then plugged it in and charge it completely
If that does not fix your problem there might be an issue greater than just the battery and you will have to see an expert to see whats going on
Sep 02, 2011 | Toshiba Satellite Pro L300-EZ1501 Notebook
Zune is completely dead when not plugged into my computer
the battery is not retaining any power. the only reason it works while it is plugged in is because there is power go directly to the battery
Jan 11, 2010 | Audio Players & Recorders
How to maximize battery life of a laptop
In addition to all these excellent suggestions don't plug your computer in with the battery installed every time you need to use it. Most manufacturers don't recommend uninstalling the battery (unplugging it) while using it. The truth is, though, this repeated charge and discharge cycle from plugging in your laptop will significantly drain the life of your battery because it is only good for so many charge cycles. So if you're in a situation where you don't need to use the battery unplug it and just use AC power. Also don't always run the battery completely dead when using it. It is best for modern li-ion batteries to be charged to full when they still have 15-20% power still left in them. About every 10 discharge cycles it is best to run the battery completely dead as this will reset the battery meter in the computer so that it can read the available charge more accurately.
Dec 12, 2009 | HP Pavilion dv6000z Notebook
Does my iphone 3g have a dead battery or fried logic board?
Hello
This sounds more like a battery gone bad and a charger that's not working correctly. How much warranty do you have? I have AT&T service. My battery went bad and AT&T service said they weren't supposed to do anything about a battery but they sent me a battery and charger at no cost. Worth a try.
Aug 05, 2009 | Apple iPhone 3G Black Smartphone
Battery died, replaced with new one but still won't start.
The old battery must have shorted out internally. That is why it went dead out of the blue.
Here are my thoughts, in random order, on other possibilities >
  • Get a 2amp trickle charger and charge the battery for 6 hours. The starter could be robbing most the juice leaving too little for a good spark. pull the spark plugs and replace with a set of stock plugs. Check for spark.
  • A kill switch is on.
  • Check the fuses
  • Petcock fuel pickup screens are plugged up.
  • Water in the fuel
  • Fuel pump (if it has one) may have lost it's prime, become plugged up, or quit working.
  • The engine may just be flooded.
  • the CDI / computer may have reacted to the battery short and gotten fried.
A “very helpful” rating for this answer? Thanks!
Jun 12, 2009 | 1992 Yamaha TDM 850
Apple screen
Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge normally, just enough so that it can come on and sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, wait few minutes, charging. It should work after letting it sit plugged up to the computer.
Oct 17, 2008 | Apple iPod nano
Dead phone but keypad flashes
replace the LCD + flexcable on the phone.
Aug 02, 2007 | Motorola Mobility RAZR V3
Nikon Coolpix S210 Digital Camera Logo
185 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
