Question about Kenmore Elite 45986 Front Load Washer
Knife puncture inside my dishwasher on the top right.
I have a kenmore dishwasher thats probably 5 to 10 yrs old and i loaded it and when the cylcle finished and i opened it to unload it I noticed that there was a knife stuck inside the wall of my dishwasher on the top right, its like a slice not very big about 1 and a half to 2 inches gash like a stab wound, what can i do to repair this the dishwasher still works but i dont want any water damage. PLEASE PLEASE HELP CANT LIVE W/OUT MY DISWASHER, BUT CANNOT AFFORD TO BUY ONE!!!!!!!
  • 42 Answers
You could clean the area very well, dry very well and use a waterproof caulk made for bathroom/showers (from kmart, walmart, etc) and carefully squirt and smooth (per directions) into the gap. Let dry per directions on caulk. This should last a while, but should be checked everynow and then to see if it's loose.
Posted on Nov 10, 2007
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
How do I fix my Kenmore washer spin cylcle? It
if your machine is a top load , less than 15 yrs. You most likely need a new lid switch. The machine will not drain or spin if the top lid is open.
Dec 12, 2009 | Washing Machines
My dishwasher won't drain. It is a Kenmore and about 8 yrs old
There is a panel tht separetes the top from the bottom you need to unscrew it. Place a pan under it after you see a little spout/drain hanging down that is probably fill with gunt what ever water that is in it will drain out clean it out , replace it after you've let the water run out. once you've screw it back see if your dishwasher is draining correctly.
Nov 17, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
How do i remove top or front cover on GE washer
2 clips 1 one each upper corner about 3 ins in use putty knife to release clips pull panel forward at top and lift off
Nov 20, 2008 | GE WWSE5240D Top Load Washer
Dishwasher won't cycle through to rinse/dry/stop
Your timer switch is most likely defective.
It probably needs to be replaced.
It is like a clock with switches at different times
If it is stuck at a particular time it will run there forever.
Before servicing disconnect power!!!!!!!!!!
You can remove inside door panel with about 6 phillips screws or so.
Timer is directly attached to the dial on your machine.
These cost about $100.00 or less.
Can also be found used online for cheaper.
Oct 26, 2008 | Kenmore 24 in. 17512 Built-in Dishwasher
Water will not drain
check for dirty filter it's inside under drying element
Jul 06, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 665.16389300
Test by pulling out the lower rack and run an upper load, it may just be a loading issue. Some washers are better than others, in that they have stronger moters and impelors than others. The impellor may have something like a fork, knife, or broken glass in it.
Jun 17, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore washer/top load
Try Washer Magic, you can buy it at your local Menards, Ace Hardware or look at line. I have never used it.
Let me know how it works for you.
May 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Top rack not cleaning
load 4 cups right side up in all four corners of top rack, move all wash arms to a known positon(pointing foward just want to check there rotaiton). start diswasher, when you hear it start washing give it 30 sec or so andpop it open try to focus on middle spray arm when opening, shlould be turning quite well. and glasses sould be starting to fill. at least thats how it SHOULD operate
Feb 25, 2008 | Dishwashers
Kenmore Elite 45986 Front Load Washer Logo
162 people viewed this question
Sal De
 Brian Main
Brian Main
