How many ton is this air handler? Rheem RCBA 3765GH17 B
  • 614 Answers
3 ton Rus
Posted on Jul 05, 2009
Dealing with a corsaire RCBA 3765GH17 this is a 3 ton unit right?
right --now what is your question
comment to get answers
Oct 16, 2015 | Heating & Cooling
Rcba 4882g how much is it to replace the central AC condensing unit
This will be dependent on the capacity (tonnage or BTU/Hr) of the condenser, its location and how much refrigerant will be needed to added / replaced - plus the labor to do it. A typical 2 - 3 ton residential system (air handler / condenser - no duct work, etc.) can run $2k and up.
Jul 04, 2014 | Rheem Heating & Cooling
How do you clean the fan in a rheem air handler?
Pull the blower assembly...2 screws on the angle bracket holding the blower & disconnect the wiring if needed to the motor.
May 28, 2014 | Rheem Complete Split System Straight...
Is their a way to reset air handler fan?
check to see if the starting capacitor is good
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
I just installed strip heat Rheem RXBH-1724A10J 10KW 208/240/1/60 into Rheem 14AJM36A01, RHPNHM3624JC, 3 Ton 16 SEER Air Conditioner Split System W/ GE's Variable Speed thermostat Pro 701 and it ran up...
This will help you.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Jan 20, 2011 | Heating & Cooling
Ineed to now how many ton is a rheem model number rbhc-14jo7nfd air handle
Hello, that unit is 800cfm on High speed. One ton of cooling requires 400 cfm. Thus your unit is a 2 ton capable air handler.
May 19, 2010 | Heating & Cooling
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
635 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
