Question about Pioneer GM-5100T Car Audio Amplifier
How do I hook up the REM from an amplifier to back of Sony CDX-F5
I know how to hook up everything from amp, but the REM, how do I hook up to stereo Sony CDX-F50 ?????
  • 113 Answers
To the blue wire on the back of the radio
Posted on Jul 04, 2009
What is rem
rem means remote on the amplifier which means your amp will turn on when ur radio turns on the remote wire goes from the back of the stereo usually always a blue wire to the rem on the input to the amp
May 23, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Won't turn on & don't know how to hook up to a 1963 pickup.
Don't get confused, it's very simple. +12v----direct supply from battery.
REM---also 12+ supplied from igntion switch. (when the key is turned on, this supply should have 12+ to on the amplifier.
GND--12- minus (negative)
Try it you will be able to set this up. REM can also be used with a single switch which can break the 12+ when amplifer is not in use, or else this will take all ur power battery. You can place a fuse on 12+. Thanks
May 15, 2010 | Crossfire VR302 Car Audio Amplifier
My amplifier in my car only works on the radio setting I think it is somethig to do with the remote wire but I had the same harness in the car and thought It might be that but when I connected the new one...
not sure where the amp remote wire is connected at this point (possibly a power antenna wire?) but you should find your rem wire and hook it up to your stereo's acc wire. The wire should only have power when the car is in acc/run settings and no power when the key is on the off position. this assures that no matter what function on your head unit you are using, the amp will always be powered up.
Sep 17, 2009 | Sony CDX-GT220 Car radio CD/MP3 Car CD...
IPOD to Sony Xplod CDX-S2000 CD-R/RW EQ3
you car stereo doesnt have any aux inputs you can check up more on this site
http://www.crutchfield.com/p_158S2000/Sony-CDX-S2000.html?tp=5684&tab=features_and_specs
the rca inputs are for a pre amp or an amplifier
Jul 28, 2009 | Car Audio & Video
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Jun 03, 2009 | Sony CDX-CA810X CD Player
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
Visonik 350watt Amp Doesnt Come On....
With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Oct 06, 2008 | Visonik V117SX Car Audio Amplifier
SONY CDX-M8800 STEREO
Red (accessory wire)- goes to hot wire that can be turned off.
Yellow (constant wire) goes to your cigarette lighter
Blue/white is your amplifier remote turn-on wire.
Probably have green and green/white- brown and brown/white-white and white/black, and another color for speaker wires.
You can hook one pair up to your cd player and find out if it's hooked up to the right speaker channel.
Orange (remote antenna) wire.
Apr 20, 2008 | Sony CDX-M8800 CD Player
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
Car Stereo Installation - Full Power Problem - New Stereo
The rca cables that thin littel wire u can use it to turn on your amp so it will go the redio amp rem wire and back to the rem for the amp.
Aug 27, 2007 | Car Audio & Video
Pioneer GM-5100T Car Audio Amplifier Logo
236 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
