Question about Kenmore 45081 Front Load Washer / Dryer
Model Kenmore 417.43042200. Timer sticks and must be advanced by a click. Is there any way to fix or must I replace the timer?
SOURCE: Washer wont progress through the cycles, suspect timer.
I was able to fix the problem by replacing the timer ($106 CDN). Thanks for everything.
Posted on Jan 08, 2009
onthejob5130
  • 640 Answers
SOURCE: Timer Replacement
theres 2 screw at each in of unit,,,if you dont see the uou have corner caps,,just pull them off wit your hand,,,..front right and left console coeners..onthejob
Posted on Feb 01, 2009
  • 117 Answers
SOURCE: How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
Posted on Mar 02, 2009
localwonder
  • 6784 Answers
SOURCE: I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Posted on Mar 03, 2009
  • 107 Answers
SOURCE: Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Posted on Mar 13, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My drier timer doesn't always advance to the next minute - it just gets stuck on a minute and continues to tumble but not dry
My older dryer and washer use to do the same thing...
Here is why: There are copper contacts on the inside of timer that need to make "contact" with the next little contact in order to "advance" through the cycle.
Two solutions for a fix...ya! (get it? Fixya! lol) (one is free!!)
Fix#1 (this worked on both my machines) : Advance the timer clockwise about 100-200 times. (you'll here click, click , click and so on and your hand will get tired but works 80% of the time). What this does is "clean" the contacts.
Fix#2: Replace the timer. You can enter your model number at parts store below and see a complete parts breakdown and order and replace timer.
Appliance Parts
Feb 08, 2015 | Maytag Dryers
Model #417.41142000 Circuit board has been replaced to correct drum not spinning. Now timer won't advance.
are you Shure that the cable has not come off the spin pause button or from another part of the cable loom its worth checking eric
Dec 26, 2017 | Kenmore Washing Machines
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Kenmore 45081 Front Load Washer / Dryer Logo
230 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
