Question about Stinger Streamlight XT Rechargeable Flashlight with Fast DC Piggyback Charger
Rechargable Stinger new bulb is dim orange
After a year or so my Rechargable Stinger bulb died down to dim orange. I have been good about running the batteries down and recharging. So I replaced the bulb with a new Stinger bulb. No change, still orange and dim. What to do next?
  • 19 Answers
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website www.streamlight.com and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
Posted on Aug 28, 2009
Do I have to change the whole headlight or can I just change the bulb?
Typically lights don't just go dim. If your headlights are dim, you could actually have a alternator/battery charging problem. I would have your battery and alternator tested ASAP! Because if your alternator is bad, your car will die when the battery runs out of juice, which could leave you stranded.
Dec 22, 2014 | 1997 Ford Taurus
Why would running lamps quit, left headlight is very dim DRL light on dash flashing?
Have your alternator checked yet? Your alternator is what actually powers all of your devices and lights when the car is running. When it is failing it will cause lights to dim. Checking connections, fuses and your alternator should lead you to a good start! Good luck!
Nov 12, 2014 | Cars & Trucks
Runs then dies
Check the battery terminals and posts are shiny clean and tight. Check that the earth wire from the battery is connected to a good clean earth point and is tight. Check that the battery leads are not corroded and ready to break at a terminal
Feb 08, 2014 | 1993 Saturn SL2
My black 360 controller with a rechargable battery, has been having 4 major problems, 1. It started disconnecting while playing Halo Reach and after. 2. My controller was not able to charge any...
Rechargeable batteries will only hold so many charges before they finally die. The controller should be fine, but your battery pack has finally died. You can get new rechargeable packs on Amazon pretty cheap, but don't buy any that seem too good to be true (like the $0.01 ones) because they are old inventory and have lost the ability to charge as well.
I think they run about $15-$20 for a new one, but it's still a better deal than needing new batteries every time your controller dies since the rechargeable ones can last for at least a couple years.
Jul 23, 2011 | Microsoft Video Game Consoles & Games
Low beam lights not working the other lights do. want to replace the headlight relay
First check that your headlights are not burned out. You may have been running on one bulb for a while then it feels like the switch or relay died when it was only the other bulb burning out.
it is fairly cheap fix. If the bulbs are old anyhow (more than 7 years), it is worth replacing them because they are fairly dim compared to new ones.
Good luck.
Please rate me - even for the suggestion
May 05, 2011 | Chevrolet Camaro Cars & Trucks
I have a large bugzapper by Stinger. I plugged it
How is the voltage to the zapper, is the circuit ok? Check it on another plug...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 06, 2009 | Electronics - Others
Headlight one side works on bright the other side works on dim
Try swapping the headlight bulbs or buying a known good bulb and testing that way. Sounds like a shorted bulb filament issue.
Apr 05, 2009 | 2004 Oldsmobile Alero
Streamlight stinger not bright
No! the last thing you want to do is get another light, if this light is still in top shape I suggest you send it back to Streamlight for warranty repair. Lifetime warranty on the light alone as far as the battery goes if you're getting an authentic Streamlight Rechargeable battery there shouldn't be a problem. If it's a knock-off battery you're on your own. Check this website out www.streamlight.com send it back to the address in contact or find an Authorized service center in your area. From what you're telling me here I honestly think it's a bad battery, I could be wrong it may be a bad switch. The switch is covered under a lifetime warranty. So take advatange of it while you can! ;) hope that helps.
Jan 24, 2009 | Stinger Streamlight 75000
Batteries keep dieing
HEY CHEF TIM sorry to miss you on hells kitchen ha ha sorry to say that these cam are battery eaters (that's wy i don't own one) rechargable battery are never any good they have whats nown as (battery memory) meanning that if you don't run it down to nothing and charge it just to keep it charged makes it werce best thing to do is buy new two day before charge i then charge num 2 go out have fun record when battery ligh comes on load battery 2 recharge num 1: DOC
Aug 11, 2006 | Olympus Camedia C-3020 Zoom Digital Camera
Stinger Streamlight XT Rechargeable Flashlight with Fast DC Piggyback Charger Logo
546 people viewed this question
Top Stinger Camping, Backpacking & Hiking Experts
Marvin
Marvin
richie46
Are you a Stinger Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
