Question about Indesit W 123 Front Load Washer
Locked light on
Indesit 61651s locked light wont go out
I have a indesit iwb71250 that the red door lock light is on constantly but we can open the door and shut although the machine will run it wont fill with water... any ideas
May be the switch is loose try fixing it with ascrew driver or the rubber hose is not fixed properly and the machine pump is taking air or the pump failure
Oct 19, 2014 | Indesit IWB71250 White 60 cm Washer Front...
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Door locked,but red light not on,wont fill with water,sometimes works but wont fill
This is a common fault almost certainly caused by worn carbon brushes in the motor. Change these and all should be well.
Dec 22, 2010 | Indesit WA 115 Front Load Washer
I have the indesit moon washer. The red door lock light is flashing when i start the cycle which is stopping the washer from going. The door is locked properly and there is nothing caught in it.
Just sorted this problem out, wife said just b4 leaving for work,oh love the door on the washing machine wont open and theres a red light on,,OMG i thought, as she said she would find the instructions when she gets home, so i got the corless drill out and a big hammer,( not needed,) lol just turned the power off and after 2 mins the door unlocked and was able to get all the clean wifes undearware out, cheers all and hope this helps
Oct 06, 2010 | Indesit Washing Machines
Indesit Widl 102 Flashing lights, wont turn on
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and/or its panel that is going bad. To start with check the Thermal fuse which is mounted to the exhaust duct inside the back cover panel. Please do accept the solution if the issue is resolved or post a comment with a more detailed question including the manufacturers name and model no# for your dryer so that I can further assist you.
Thanks
Rylee
Jun 14, 2010 | Indesit Dryers
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Apr 01, 2009 | Washing Machines
Indesit washer wont run
the door lock light flashing indicates that the door has not locked or not shut correctly,is the appliance is under 5 yrs old open the door and check the door catch,there are two gaps either side of the catch,if you look into the gaps you should see a metal pin,if the one at the bottom is not there then thats why the door wont catch,there are some screws around the door frame if you take them out and just pry apart the door frame by the catch you will see the pin at the top,push it down till you see it at the bottom gap,refit and test.
Jan 24, 2009 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
113 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
