My traction control light is on steady and my AT oil temp light is blinking as well as my emergency brake light. Help
SOURCE: a/t light is flashing 16 times n 1995 subaru legacy
if by a/t you mean automatic transmission try a power purge transmission service it may have a filter sensor that is telling you to service soon
SOURCE: 2009 subaru impreza 2.5i will
There is something wrong with your transmission (and most likely your ABS and TCS). You'll need to have the trouble codes read and diagnosed.
SOURCE: 2010 subaru legacy emergency brake indicator light comes on intermitently and sometimes stays on
Check the park brake switch and the fluid level in the brake master cylinder, both will cause the light to flash.
