Question about Sansui Audio Players & Recorders
My sansui z7000x (1985) has started acting eratic. if pluged in it will turn itself on and off. putting a backwards e in the red numeric led. at this time the keypad becomes useless. if turned off with the clock set and turned back on it will stay on channel for maybe 30 minutes then act up again. i wonder if it experienced a power spike? is it fixable?
SOURCE: TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Posted on Jun 25, 2007
Kazong
  • 152 Answers
SOURCE: assistant
check your sleep timer settings thats the most comman prob
Posted on Dec 18, 2007
  • 4 Answers
SOURCE: TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Posted on Jan 21, 2008
  • 79 Answers
SOURCE: Yamaha R-V905 constantly turns itself off
Two things I think are happening. It is overheating and it has suffered some sort of damage to a component inside. Try to make sure there is ventilation on all sides. Can you remember a time where you did not have adequate ventilation for this device? If so maybe that is what caused the part inside to fail.
Hope this helps
Thanks for reading!
Posted on May 02, 2008
tech48
  • 624 Answers
SOURCE: Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Posted on Jun 18, 2008
How to turn off startup sound in sansui LED
Live with it. No way to turn off startup sound of your Sansui LED TV.
Nov 27, 2014 | Sansui Televison & Video
I have 42" ,Sansui plasma tv .model number Sty 0342 . when i switch it on , the power led chages from red to blue, then suddenly goes red again .i've changed the power board but it keeps doing the same...
I have sansui television 42"model number STY0342, plasma 3D.when l turn it on sometimes it takes time to switch on after turning it on.it will change the standby light to blue.what might be the problem.
Dec 26, 2013 | Televison & Video
Electrical "" turn signal switch
year, make, model, and engine size?
Sounds like a turn signal switch to me.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 26, 2012 | Cars & Trucks
I wired my new starter backwards, now I have no electrical power to anything.
You more than likely burned out a fusible link. It's an in-line wire that acts as a fuse that's usually attached to a large red wire.
Jun 05, 2011 | 1985 Buick LeSabre
Sansui sy 20 eye tv- when power on/off only red led works, green led not working
Please give me sansui sy 20 eye service menu code...pls urgent
Jan 24, 2011 | Televison & Video
I have a 1985 toyota pickup (fuel injected)with a 22re engine, it will run on starting fluid, when i spray it but it wont run otherwise, just put in a new fuel pump, thanks for youre help,
Alright, i have a 1987 Toyota 4x4. it has a 22RE full injected motor..it was able to run, but it was running rich, and idling pretty eratic..and then now..it only starts up..and dies. after like 5seconds.
Jun 15, 2010 | 1985 Toyota Pickup
1986 Chevrolet Celebrity - Surging Eratic Acceleration
Sounds like you have a vacuum leak somewhere causing the engine to flood.Check all hoses coming fron intake manifold.
May 10, 2009 | 1986 Chevrolet Chevy
13" sansui AC/DC 12 volt use
Did you check the fuse inside the plug on the 12volt cord?
Feb 01, 2009 | Sansui COM312AD 13" TV/VCR Combo
113 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
