Question about GE Profile JTP18 Electric Single Oven
Aluminium sheet has melt with the base of my oven
Is it dangerous
The fuse on my delonghi def905gw1 free standing oven keeps blowing when I turn it to oven or fan oven
STOP USING THE OVEN NOW! ELECTROCUTION HAZARD.
Hard to diagnose, but SAFETY alert, all inspection work MUST be done with the power off - some places cord disconnected.
Oven electricity is dangerous.
The oven right now could be dangerous. Call professional or the last 'repairman'. make that call if you value your life or your partners.
First hunch is you have had work done on the oven before, badly and something is shorting, wire insulation melted, or a spade type lug moved. Multimeter will reveal the truth.
An oven service manual to track the short would be nice, but I expect
a blacked or charred spot will be visible around either the switch or wires leading from it.
May 24, 2014 | Ovens
The drop down door on my Miele Oven H4271 won't stay open - it bounces back up which is dangerous and inconvenient.
Contact Authorized Service Center if it's under warranty, else get any local expert to help you with it. They're likely to change Locking System of your Oven.
Mar 29, 2014 | Miele Ovens
The oven and separate grill work but the cooling fan no longer comes on. Is this dangerous?
Yes, it could be dangerous to use, as the fan is designed to keep it from overheating, so I would recommend that you do not use it until is repairedor repaired.
Nov 17, 2010 | Ovens
Microwave grinding sound
its not dangerous, if you can stand the noise, it would cost you around $25 to$75 to fix it even if you do it yourself depending where you get the repl parts
Oct 25, 2009 | Ovens
Oven shelve falls
You are right, this is very dangerous. It is possible that your oven walls expanded, but honestly, I've never heard of this before, but this is what it sounds like!! I would call Sears right away and have them come out and check it. If the walls did expand, you have a defective oven and they should recall that model. I'd really love to hear the outcome of this complaint, so please let me know how everything turns out for you. And you better get it repaired before Thanksgiving. Have a great day!
Sep 07, 2009 | Ovens
Sharp MW won't shut off
Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
Jun 14, 2009 | Ovens
Oven - Very bad gas smell
Very Dangerous! turn off supply to appliance, supply ventalation and call service tech. If you are very familiar with gas appliances and know what you are doing then you can try to locate the leak using soapy water or leak detector liquid. make sure all flames and other possible sources of ignition have been eliminated. Keep room well ventilated. Spray leack detector on all fittings and look for leaks replace or tighten parts as needed. This responce is asuming you have not blown up already, seriously dangerous situation you have there.
Jan 07, 2009 | Ovens
WHIRLPOOL SUPER CAPACITY 465 MODEL: SF368LEPQ GAS SMELL
I will rarely say "call a professional" here because this is a do it yourself site right?
However, in this case, you obviously have a gas leak and/or malfunctioning gas valve.
Unless you have experience and training in detecting gas leaks I highly recommend shutting the gas off to the unit, ventilating the area, and calling a pro.
Gas can be very dangerous if handled improperly and a mere spark can "make house go kaboom".
If you are smelling it strong enough that you have to open windows, it is a potentially dangerous situation.
Dec 06, 2008 | Ovens
Whirlpool Gas Oven
gr00vy It is a very dangerous! Stop use the oven and call a professional service. In such situations it is always better to overreact. Gendos...post back
Feb 19, 2007 | Whirlpool GBS307PD Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
67 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
