Compressor running but not cooling. Evaporator fans not spinning??
SOURCE: We have a true T49F freezer and the evaporator
Freezers have a sensor that is referred to as a "Fan Delay/Defrost Terminator". It senses the temp during the defrost cycle. Usually, when the evap temp reaches about 50 degrees, there should not be any frost or ice on it. This device terminates the defrost cycle. It also keeps the fans off so warm air is not circulated. When the evap gets to about 20 degress or so, the sensor switches on the evap fans. If the fans are not coming on, either the sensor is bad or the evap is not reaching the proper temp to cause the sensor to turn on the fans.
Hope is helps to clear up some things and point you in a direction as to what might be going on.
SOURCE: evaporator fans do not come on, why would
There are three main reasons the fans would not come on.
1: A bad door switch. There are switches on the top part of door frame. They turn fans off when door is opened to prevent warm air from being drawn into unit when door is open. If a switch goes bad the fans will never turn on.
2: Refrigeration problem. The fans are tied into a temperature switch called a fan delay. The fans will not come on until the coil is well below freezing. This is to prevent water spray after a defrost. If unit is low on gas or has any other cooling issue the fans will not come on.
3: Bad fan delay switch. If the fan delay switch becomes "stuck open" the fans will not be energized.
Feel the back of your evaporator coil, if it is very cold and frosted you probably have a bad fan switch, or a bad door switch. ;)
SOURCE: I have a True Freezer Model T-49. It works fine but every 3 or 4
This sounds like a stuck relay to me. I have seen this problem before. The defrost clock kills power to the compressor relay coil during defrost. If the contacts in the relay are welded together the compressor runs while unit is trying to defrost. On newer units this relay is mounted in base of unit on the side or back of the electrical box near center bottom of unit. The compressor relay is a small rectangular box with 4 wires attached. It can be replaced with a single pole 20 amp contactor with a 120 volt coil/ or 240 volt. Check the units name plate voltage rating and ratings on old relay! ;)
SOURCE: compressor runs bypassed thermostat with wire that
If you have just turned it on it takes awhile for the fans to come on. The evaporator coil has to get cold about (10 to 20 degrees) and make a klixion fan switch to turn the fans ON.... Is the evaporator coils getting a frost pattern on them??? If not then the system may be low of Freon.. If the coil is completely froze up and you are getting frost back to the compressor..... then you have a bad fan switch or a door switch.... If you have a wiring diagram you can trace out the wiring.... It is usually down by the compressor or control panel... hope this helps.
Could be a number of things. It has a thermistor that sits on the evaporator to keep the fan off until it gets cold. It also has a switch above the door that switches the fan on when the door's closed. It could be a loose connection in the wiring, or, lastly, it could be a seized fan
