Problem for DVD Players
Generic problem for all DVD Players
Disk won't load
I watched a dvd this morning with no problems. On trying to watch another one, having made no adjustments to any settings or not even turning the unit off, (and also trying the same dvd that I had played earlier in the day) I see a 'loading' icon on the tv screen but a message saying 'no signal' then on the led display on the dvd player it say's 'No'. Of course then I can't watch the dvd.
Same Problem
Jan 07, 2009
-   panasonic vcr/dvd combo 4763... won't play any dvd's including the dvd lens cleaner. just says reading over and over -
jlflogix Jan 07, 2009
-   Some DVD disks won't load while others will. All DVD's load and play fine on other DVD's I have, so clearly something's wrong with the Sony machine. Any suggestions?-
gargar74 Jun 27, 2008
-   Same problem with dvd-r135. I don't understand the solution provided. If nothing was changed from previous setting when it did play the dvd, how checking all the connections, etc. would help. Beats me!!!-   Guest Mar 23, 2008
-   I have the same problem-   Guest Feb 16, 2008
-   Tried to play DVD. First display says "LOAD" then it says "NO". Last time I used the DVD, it worked fine. No adjustments have been made since last successfull use.-   Guest
Solution #1
posted on Nov 10, 2007
Rank: Wiz
Rating: 85%, 238 votes
I would verify that connections between the DVD player and the TV; then go into your DVD’s control panel and re-set to original factory settings. I would also make sure that your TV’s settings are set to the correct connection settings as well.
It would also be nice if you included the make, and model of the DVD player and which connections are you using to connect to the TV.
Popular Solutions for DVD Players
Philips Magnavox MWR20V6 DVD Recorder / VCR Combo
1 Solution
Questions and Unsolved Problems for DVD Players
We are looking for a new DVD recorder that will last longer than our last one a RCA. we just want...
(More)
We are looking for a new DVD recorder that will last longer than our last one a RCA. we just want simple recording from our TV or computer.
what sort of scart lead for product dvp3360
No response to pushing any buttons on front panel. Power on light very dim, just flickers when power...
(More)
No response to pushing any buttons on front panel. Power on light very dim, just flickers when power button pushed. Is this ready for the recycle bin - it has hardly been used?
I need the 3 digit setup code for a DWM-380 Sanyo DVD player to work with my universal remote. I...
(More)
I need the 3 digit setup code for a DWM-380 Sanyo DVD player to work with my universal remote. I tried 649 and 654 to no avail. Please Help!!!! John Baker
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 26, 2007
DVD player stuck at "Loading" screen whether DVD is in it or not. It will automatically show this label when turned on. Cannot access remote menus because of loading screen. HELP! No support on Toshiba website or owner's manual. HELP!
Comment by Guest, posted on Dec 17, 2007
OUR DVD DOOR WONT OPEN AND IT READS ERROR ON IT
Comment by neerajlink, posted on Nov 25, 2007
this morning,
i was playing it, then i thought of breaking code to get free region..
in that process......
1st time......... i was getting dvd payer image in screen (mean it was processing)
i tryin use sugestd codes, ..in videohelp.com........
after couple of time, it didnt happen. (was tryin playin region 2 dvd)
after this, i m at message of no signal only, not even i'm getting atleast,,,,a dvd readin image or sayin wrong region or any.....
directly
i tryin all ways, so far....
now even, i switch on plyer, it starts, it stays in power,,, in a second...
screen says no signal..
pls give ur post
Comment by team2k8, posted on Nov 25, 2007
I have a Toshiba SD-K860SU model DVD player. It was working for a while but now it stopped working. Whenever open the drive tray and either put a disk or not, close the drive tray. The panel shows "Load" and then stay that stage. No matter there is a disk or not, when turn on the power, the panel always shows the "Load". May be it is dead?
Comment by hatchling, posted on Nov 12, 2007
Loaded disc, however, it just says "loading" on the tv screen - we have unplugged the unit, etc. and nothing happens.
