Question about Echo Rapid Loader, Trimmer Head
I have echo 230 trimmer that runs on idle and wide open but not half way i have rebuilt the carb, new plug, check the spark arrestor screen, vent, gas filter, but still the same
  • tonyexp Jul 03, 2009
    I have done this still no help. its funny that it will not run from a little above idle to half throttle seem to run out of gas but at full throttle it runs great
    Sorry about that i did not mean a thumps down but thumps up how can i change my rating to show thumps up
  • 1,041 Answers
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 03, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
  • Jim Parker
    You got it.
    Thank!!
    Jim
SRM 2400 trimmer. Why doesn't it start?
Ralph, if you are getting fuel, spark and have compression , I suspect the muffler screen is plugged. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Small Engine Repair Cleaning Carbon Buildup on the Exhaust Port Muffler on...
Echo trimmers and loss of power EXHAUST PORT CLOGGED
Symptoms Repair Of Clogged Spark Arrester On Grass Trimmer
My Aunt Echo PB 2100 Blower with Clogged Spark Arrestor Screen
Apr 17, 2016 | Echo Garden
I have a hasqvarna 125 b I have put new starting coil on it,new fuel lines, rebuilt carb, new primer pump, new plug. It is getting spark, the plug is wet, but it still won't start.
Check your muffler's spark arrestor screen for clogging. Also test your compression. It needs to be be at least 100 psi for the engine to start.
Apr 24, 2015 | Garden
I have an Echo Grass Trimmer, GT2000. It runs and idles ok, will not up rev up to speed. It runs at about 1/3 of what it should, on high. I've replaced the spark plug; taken the carb apart and cleaned...
This sounds very much like a blocked spark arrestor in the muffler outlet, or the exhaust port is blocked with carbon, remove the muffler and look up the open exhaust port for signs of carbon build up, somewhere in the muffler there will be a mesh gauze ( spark arrestor ) either clean this or remove it completley.
Sep 08, 2011 | Garden
Ryobi 790r trimmer has low power and stalls
Maybe a quick fix and maybe not
check your muffler the factory puts a spark arrestor screen that tends to plug after awhile
there is a little plate on the side muffler that needs to be removed to access the screen you may need a torx bit or allen wrench to remove
you may have to remove the back half of the plastic cover to access the screws
remove screen and clean with carb. cleaner or equivalent make sure you can see through it and reverse the procedure to put it back
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Echo Rapid Loader, Trimmer Head Logo
506 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
