question re: RAW/jpg mode. set it so it shoots BOTH RAW and superfine Jpg... and now when i go to put images on computer both images are jpg...why? When i set it to JUST RAW format its fine, just comes out as RAW as it should.
I'm trying to find a LCD Flat panel TV that I can hook a Canon 40D camera to and use it for a...
(More)
I'm trying to find a LCD Flat panel TV that I can hook a Canon 40D camera to and use it for a monitor while using live view.
40d camera got damp...now lcd not working...after a few shots shutter stops working , flash strobes...
(More)
40d camera got damp...now lcd not working...after a few shots shutter stops working , flash strobes but doesnt flash
I have a canon 40d. Its making screeching noises whenever I take pictures. I thought it was the lens...
(More)
I have a canon 40d. Its making screeching noises whenever I take pictures. I thought it was the lens so I changed to another one. The same noise is produced when taking picture. Is there something wrong with my shutter? Sounds like a part needs oil or something? It should be a very smooth click when pictures are taken, not a screeching sound right?
Canon 40D with Canon 50mm 1.8 lens ERR 99 Shooting is not possible Turn the power switch to and...
(More)
Canon 40D with Canon 50mm 1.8 lens ERR 99 Shooting is not possible Turn the power switch to and again or re-install the battery. I did all of it several times. Removed all except time battery not sure where it's stored. Plan to clean contacts and try another card and lens. This seems to be a common err problem. Does it require installing software? update like computer problems? Thank you for any suggestions Fernand
when i press to take a picture the shutter only does the first part of the release. I have to take...
(More)
when i press to take a picture the shutter only does the first part of the release. I have to take the battery out to get it to release. It does the same thing every time. I have taken the card out as well and nothing changes
