Question about Canon Sure Shot 80 Tele/Date 35mm Point and Shoot Camera
How to put battery in camera
You said there is a door at the bottom. How do you open it and can you describe it.
  • 571 Answers
It is usually round with a groove in the middle. You are able to open it with a coin or similar.
Posted on Aug 18, 2009
How do I remove the battery pack that is stuck in my Sony FD100 Mavica
put dot of superglue on bottom of battery and put a string in it too. let it dry for couple of hours and pull gently on the string while coaxing the battery and it will slide out eventually. another method is to swing the camera with battery door open while aiming the battery to be "launched" toward a soft object or your hand and cause an emense G-gorce to they battery to expel it from the camera :-).
Apr 30, 2014 | Sony Mvc-fd73 Mavica Fd Floppy Digital...
Removing battery
The battery door is on the bottom of the camera. Hold the camera bottom up with the battery door to your right. Slide the oval spring-loaded battery latch all the way to the right and gently pull up on the battery door.
Mar 20, 2014 | Nikon COOLPIX L6 Compact Digital Camera...
How do I open the battery door?
With the display screen facing you, look on the bottom right for the door for the batteries. There's a tiny grey slide switch on the right side of that door with polk-a-dots that you have to slide toward the screen side of the camera. Hold the camera upside down and while sliding this switch away from you, you can slide the door to the right, which opens the battery compartment.
Jan 19, 2013 | Nikon Coolpix S30 Digital Camera White
How do you get the battery door open on the sharper image u-video camera?
The battery door is at the bottom of the camera, just below the little box with THE SHARPER IMAGE in it and opens easily ...if you know the trick. (The tripod mount is in the bottom of the door.) using your thumb, press down on the tripod screw hole and push on the door from the front of the camera toward the rear and the door pops open. Reverse the procedure to close.
Dec 25, 2010 | Cameras
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
I have a kodak Z812 IS. How do I put replacement battery door on?
open the screw on the bottom and slowly pull apart the two sides. Dp not pull them apart completely. the battery cover should pop out. do not use force. the same way insert the new one. Click the panels back in place and screws in .
Apr 29, 2010 | Cameras
Hoe to remove camera card
Open the battery/card door on the bottom by sliding the catch toward the back then sliding the door to the outside following the arrow. Press down on the card with a fingernail and it should pop a bit. Grasp it and pull it out. It may be easier if you let the batteries drop out first; just make sure you put them back in the correct way.
Mar 13, 2010 | Nikon COOLPIX L18 Digital Camera
I dont no how to put the batteries into my mercury cyberpix s-555v digital camera. and i need help and it doesnt seem 2 turn on or i dont no where is the power on and off button. can u help 4 free. thank u
look at the battery and then the camera,matching up the positive and negative,close camera door,the on button is the little button on the left at the top of the camera,hope this helps you
Nov 26, 2008 | Mercury Electronics CyberPix S-550V...
Disney princess camera
trentshoffne,
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Canon Sure Shot 80 Tele/Date 35mm Point and Shoot Camera Logo
141 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
