Question about Traulsen Freezer Refrigeration 4 - 1/2 Door ''G Express Series'' Upright Reach-In Commercial Freezer
Freezer wont freeze, compressor always running, refrigerator not cold
    Genius:
  • 3,422 Answers
HI,
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Jul 03, 2009
Freezer is too warm. We have cleaned all vents but is still in the 40s
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
Regards.
Sep 15, 2011 | Maytag Freezers
It is running but is not freezing the food
Regards.
Sep 15, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
The freezer is not working... It has been slowly warming up for a few weeks. What could be wrong? Also, does this mean that the fridgerator is next to go? We have a GE Model # GSH25KGPA WW
Good luck.
Sep 14, 2011 | Freezers
My freezer is no longer freezing
Regards.
Sep 14, 2011 | Hotpoint Freezers
I own a frigidaire model # CF-5D-L*2 manufactured in Feb. 1987 and it stopped cooling off. I've looked at the underside of it and don't see anything off the bat that would be wrong with it. Can you...
Good luck.
Sep 13, 2011 | Frigidaire Freezers
Not freezing. coolant line gets cold then warm after compressor starts
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 17, 2011 | Frigidaire Freezer Refrigeration White...
The freezer side of the unit will freeze until it freezes over and will no longer keep the freezer frozen. The freezer then has to be defrosted so it can freeze again.
heatman101
May 08, 2011 | Maytag Freezers
Freezer runss but does not freeze
heatman101
Apr 04, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Power but wont run the motor to freeze
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 05, 2011 | Haier 13.6 cu. ft. / 385 liter Upright...
Hi! I have a GE Freezer Model FUF14DTARWH that runs but the coils are not getting cold enough to freeze???
heatman101
Nov 15, 2010 | GE 13.7 cu. ft. General Electric Upright...
Freezers Logo
990 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
