Question about Nokia Cell Phones
Cannot adjust volume and keep it .when i adjust it, the next time i try to use i have adjust it again
How can I set time and volume?
These 2 things can be done using the "Menu". (You can also adjust the Volume from the Driving Screen - tap bottom left area and slide the volume bar to adjust the volume).
From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen),
Look for, and tap on "Change preferences".
1. To set Time:
On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
2. To set Volume:
On the next screen, look for and tap "Volume preferences". You can then tap on the bar (position) and test/hear the level of the sound. And/or you can select "Link Volume to car Speed" ... and tap Done.
Feb 11, 2016 | Tomtom One GPS
How do i reset a kurio 4S
You can perform a factory reset by holding the volume + button and power button at the same time. Release the power button after 5 seconds but keep holding the volume + button until a screen appears with options. Use the volume + button to scroll down to factory reset and then press the power button to select it. Next you will have to scroll down using the Volume + button again to highlight yes and press the power button to select. Once the reset is finished, you have to set up the tablet again, but at least it works. Hope this helps.
Jan 19, 2014 | Kurio Touch 4S Handheld
LA76931 ICS SERVICE MODE
First do volume ''00''
than try this.
1. Menu>6483 Than use mute or display for next page.
2. Menu>6568 use mute for next page
3. Press Alt on remote with vol- of tv panel key. do same for next page. than press on remote Menu>6568> mute for next page4 to19
Sep 16, 2012 | Televison & Video
I have a toshiba 26LV610U that has low volume. Most of the time I keep the volume at 40 - 50, but some DVD's are impossible to hear at max. Is there an internal volume adjustment that will amp up the...
Tries tv menu Sound Setting adjustment.Tries all the setting to the max like treble,bass,balance and surround sound is on.This should help make the audio louder.
Jun 10, 2011 | Toshiba MD19N1 19 in. TV/DVD Combo
How do I adjust the volume control on my samsung t255g cell phone?
Main Menu Settings Sound Profile Find your selection (example "Normal") Hit the "OK" button Then there are three categories to choose from on this next screen (call, message, phone) use the left/right keys around the "OK" button to choose which one you want. Use the up/down keys around the "OK" button to modify the selection For example, use the right key to go to "Phone" and then the down key to make adjustments. Keep hitting the down key until the writing in the yellow menu says "volume" Hit "OK" From there you can adjust the volume
If you want to adjust call volume, highlight "call" with the left/right keys Use the down key to go in the yellow area and keep pressing the down key until you see "ringtone volume" then hit "OK" and it gives you an option to adjust ringtone volume
Hope this helps!
Feb 27, 2011 | Cell Phones
Toshiba LCD 19AV600U - everytime I turn it on, the volume is at the loudest level. I adjust it and it works while viewing, but doesn't stay at that level when turned off. The next time I turn it on, it...
your mainboards memmory is failing you will need a new mainboard very common problem on that model set try shopjimmy.com or Andrews Electroncs
Nov 29, 2009 | Televison & Video
Uniden cordless: Adjusting ring tone volume down
If it is like mine....push on one of the volume buttons (up or down,doesn't matter) and the phone will ring. WHILE IT RINGS, push the button again and it should scroll to the next ring option. Keep pushing WHILE it rings to scroll through the ring options.
May 14, 2009 | Uniden Cordless Phone
Wave on master volume keeps decreasing on its own
I have nver come accross a setting that will lock the volume to a set level before, but here are a couple of possibilities that you may want to investigate for the cause.
  1. Not all programs use the master volume control, so do, but most adjust the sound by the wav output. Put the mixer onto the desktop, open things like winamp, media player etc and adjust the volume controls on those to see what is doing what.
  2. If you have a multimedia keyboard with a volume control on it, make sure when your typing it's not adjusting the volume at the same time. Again, put the mixer on the desktop out of the way and type as you would normally. It could even be just the vibrations from typing setting it off.
See how you go and post back your results
May 09, 2008 | Microsoft Windows XP Home Edition
Lost instructions for sony cdx-gt11w car cd receiver
Press and hold the volume knob until the display shows clock adjust.
use the forward and rewind serch buttons (the small arrow buttons next to the volume nob) to switch hour and minute.
use the volume knob to adjust the time. When done press the volume knob to return to normal operation.
HTH
Apr 22, 2008 | Car Audio & Video
Amps and sub-woofer not working
Enter into the Audio Setup mode(press and hold volume button for at least 1 second). Next, repeatedly push the volume button until the display shows "2 ZONE". Make sure this feature is turned off. Hold the volume button again for at least 1 second to leave Audio Setup mode.
Now you need to make sure the Subwoofer Output is turned on. Do this by holding down(AM position) on the control knob(toggle stick) for at least 1 second. Each time the button is pressed, the Subwoofer Output is turned ON/OFF. the display should show "SW ON".
Next, you can go into Audio Control mode(press but do not hold volume button). Keep pressing on the volume knob until "Sub-WLevel" is displayed. Here you can adjust the amount of gain for the Subwoofer ranging from -15 to +15.
I hope this fixes your problem with it.
Cheers
Dec 31, 2007 | Kenwood Excelon KDC-X789 CD Player
Cell Phones Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
