Question about Acer Aspire One Netbook 8.9" Notebook
Can I connect to the internet through my modum and how would I do that.
I have the Zyxel ES-105A connected in the following way: LAN cable from modum connected to port 1, LAN cable from port 2 connected to my laptop which I use to log in to my modum and LAN cable from port 3...
If your modem is not also a router you can only connect one device to it. You should have a router instead of a switch. Otherwise check the settings on your modem to be sure the ports are open that are needed for the Sling Catcher.
Apr 04, 2011 | Zyxel ES-105A (ES105A)
Ps3 won't obtain ip address(no internet connection)
some networks tend to be available but the moment you try to connect,it disappears.maybe its just one of those networks that is really unstable.
Mar 08, 2010 | Sony PlayStation® 3 (60 GB) Console
How to connect my dell dial up modum to lap top
Your dial up modem needs to be ab external modem.
You can not use an internal modem from another machine unless you create a network and share your connection.
If you have an external modem then connect the modem to the available port on your laptop and let plug and play take over. If you do not have a port on your laptop and you modem has a serial port you will need a usb to serial adapter which you can get at Radio Shack.
Jan 09, 2010 | Ultra Computers & Internet
Hooking D-Link 655 to a Ambit Cable Modum with Charter Cable, Cannot Get it to Configure. When modum is directly plugged to modum internet is fine, but I cannot get throught he setup stage when hooking the...
I have dlink 2100ap wireless router any body had access my wireless network but i want to ristrect network just like network passkey how can i give my dlink 2100ap wireless router pass key please give me reply
Sep 24, 2009 | D-Link Computers & Internet
Wireless security into modum
try to set up a secure network using wpa2 with a long passphrase. also turn off the wireless signal when you're not using it.
Jul 07, 2008 | Computers & Internet
Loose connection
  1. Update the Firmware on your router.
  2. When you lose internet, look on your modem and make sure that no lights have gone out. (i.e. Cable) If this one goes out, it is your provider.
Jun 03, 2008 | Linksys Wireless-G WRT54G Router
I have on-line service and I purchased your router to get on-line service to a second computer six feet away from me. All of your illistrations show only one modum, one router, and one computer. Do you...
u need to have network card to access the other computer,and also sys 1(where modem is connected) which acts as a server should be always on in order other system to get access to net,and in the 2nd sys open Internet Explore go to Tools>internet options>Connections> in LAN settings give the IP address range..That would work fine
Apr 01, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
