My AT oil temp light is blinking and my emergency brake light is blinking and the traction control light is on steady. Please help.
SOURCE: 2009 subaru impreza 2.5i will
There is something wrong with your transmission (and most likely your ABS and TCS). You'll need to have the trouble codes read and diagnosed.
Whenever
this warning light or any other stays on in the dash it is indicating
that the systems control module (or the system sensor in the case of
lights like low oil pressure, door open indicators etc.) has detected
a fault, it then disables the system (this applies to ABS,TCS, TCM,
SRS and BCM faults and others) as long as the light is on. You must
now have the dealer hook up a special electronic diagnostic tool and
"scan" the system for the fault code that is stored for the
problem(s)
Legend of Abbreviations. ABS Antilock brake system.TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module
