Incoming mail stuck, 8 messages to come in but one seems to be blocking everything
SOURCE: Microsoft Outlook - access denied 554 5.7.1
Got through the following links.May be it will help to resolve your issue.
Click Here 1
Click Here 2
Thanks
SOURCE: need to add color to incoming msg from manager
I'm not looking at the Outlook menus right now, just Outlook express but there should be the same features. Look for a "Tools" option on the menu bar near the top.. Under "Tools" look for "Mesage Rules". Click on that, then select "Mail".
In Outlook Express there are Conditions and Actions you can select. Select "Where the From line contains people". Near the bottom there is a "Rule Description". Click on "Contains people" then either enter the boss's email or select his email by using the address book option.
For the Action section, select "Highlight it with color". In the Rule Description area, click on "Color" which will allow you to change the color to whatever you choose.
Again, the exact options and menus may be off as I'm looking at the options within Outlook Express. Outlook is a more robust product so anything Outlook Express has, you should also have.
SOURCE: Entourage Error 3259
This may be due to the means of authentication being used -- by the STMP server you are sending to and/or the authentication options selected in your Entourage setup. Mail servers commonly establish restrictions based on authentication to restrict who can send mail through them as a means of preventing spam.
Cable companies for example, and possibly your campus network, often restrict the sending of Mail to those computers that have a local connection to their network based on the IP address they are using -- i.e. where you plugged in or which wireless adapter you are connected to. Alternatively, many others require your mail client to present your user name and password to authenticate... or possibly to authenticate only in those cases when you are not connected locally.
So... to get an iron clad answer, you need to find out from the Mail server administrators what type of authentication is required. This information is often listed on "help" web pages describing how to set up your mail client... or call them if you can. Alternatively, check your Entourage setup to see how it is contacting the server for outgoing mail. Try changing the authentication method to use Password authentication if it is not already. Ultimately, the mail administrator for your Mail server is likely your best help resource.
Hope this helps.
SOURCE: entourage chrashes when I delete sent messages
If you already rebuilt the Database and still crashing, that means that your Database(Main Identity) is already corrupted and you need to start a fresh database.
Try deleting the messages in your Webmail if you're using IMAP account. Most likely, that message that was stucked in your deleted items folder is causing the issue.
If you have TimeMachine enabled, restore to the date when Entouarge last worked.
To enter voice-mail, press your VM Key, the pass code will be set as default to 0000, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you are changing your voice-mail message, you must press 3, delete the original message and reset the message followed by the #. Please watch the video attached if you go to www.abbeytelecom.com there are over 60 covering lots of topics relating to the samsung dcs
