Question about Braun Flex Integral 5550 RB Electric Shaver
Interestig, i did not know electric shavers are television sets as well!!!!!
Posted on May 12, 2008
No TX/ rx Radio Shack TRC-495
it probably jumped freq. somehow. There is now manual or anything but a picture of this radio and a few tune up rv's but thats it.I have the exact same radio and it works fine If you can put it on an oscilloscope it should tell you right away what the problem is. Then try a frequency counter.
Mar 06, 2014 | Cobra 29 LTD CB Radio
Vision 708 mixer amp
I am not sure about the LED fault lights....but I have a few troubleshooting angles to provide a start:
Try checking the power supply at the output devices and compare with the good (Left) channel.
The distortion you are hearing may be due to
low voltage.
This is a stereo amp, so you have a good (Left) channel to compare with. Use a multimeter to compare resistances (no power applied) or voltages (power on) at the components working back from the outputs of each channel. When you find a difference you have located the faulty area.
If you can get an oscilloscope it can also be used to trace the path back from the output of each amp. Good Luck Be careful!
Jan 08, 2008 | Food Mixers
Didivox in cork area
If you box is on MMDS/Teresterial:
You should download the firmware "digivox_ter_v3300.bin" and put this on your box using downloaded10.exe (This will automatically fix your problem)
(You should be able to find the file by using Google.)
1. Connect to Internet.
2. Search for the files named above
3. Save / Download the files
4. Get the cable to connect your box to the PC.
5. Connect PC to Digivox via the serial port using an RS232
6. Turn on Digivox & then turn on PC.
7. Open loader software “DOWNLOADER 10”
8. Check settings and parameters. Defaults are usually correct.
9. Browse for bin file (digivox_ter_v3300.bin )
For all files and the downloader 10 click this link and hit digivox
and select.
10. Check “app file” (default).
11. Click “download”
12. A progress bar will appear. Wait for “download complete “ window to pop-up
13. Turn off Digivox and PC then disconnect.
Enabling Key Emulator
1. Connect Digivox to TV (usually scart), cable feed and power on.
2. Perform full auto-scan.
3. Go to “main menu”
4. Scroll down to “System Information”, press “OK” to enter System Information menu.
5. On your remote control press “ 1 0 0 4 ” (ignore what happens on the screen)
6. “Key Emu” will now be visible on the screen.
7. Change “Key Emu” to ON
8. Exit menus and return to TV mode.
9. Go to a scrambled / encrypted channel and wait for update process to complete.
10. Scrambled channels should now be unlocked.
Problems with no sound
To get back sound on e4 sky1 ect just select the channel in question press menu, select installation, select manual scan, click ok on down frequency. It'll now scan for channels when its finished exit back to normal tv viewing screen go to the end of your channel listing and the desired channel will be there with sound. This can be done on any channel with no sound by just selecting that channel following the instructions above
May 28, 2009 | Digi Televison & Video
Nad C320 right channel stops working then comes back again
This sounds like the "pre-amp" section is cutting out or there is some interruption in the signal path. A few things to try:
1) With the unit off, try "working" the volume,balance and tone controls. This means, turn them up and down a number of times to clear any debris that may be in the controls themselves.
2) Work the input selector switch the same way if it is a rotary switch.
3) Try turning on/off the tape monitor switch a few times.
4) Keep track of whether this problem is sensitive to heat. Does teh channel shut down more quickly once the unit has been on for a while?
Lastly, if you can solder, look for any solder joint that appears grainy or has rings and resolder it.
Update this with your results and we'll continue on...
Jan 15, 2009 | NAD C320 2-Channel Amplifier
Ntl eurovox ireland
go back to the (Menu) screen then (installation) and (OK) on (User Installation) again enter 0000 as your pin, Now press the yellow button for (Power Scan).
Start the search @ 290.00MHz & end it @ 420.00MHz using the symbol rate of 6.887Mbaud then hit (OK) to start the scan. could take a few minutes but should get all your channels back.
Dont suppose you could post the most recent codes up please?
Dec 25, 2008 | StarView SV211K 2-port KVM...
Onkyo TX-DS494 stereo receiver won't turn on.
First, check which type of protect first.
3 seconds (DC protect) OR immediately shut down (Over Current protect)
How to confirm?
1.Unplug the amp.
2.Remove the metal cover.
3.You will see a long vertically installed pre-amp board mounted next to those large power transistors fixed by 12 screws on a large aluminium heat sink.
4.Remove this long vertically installed board mounted by 2 screws.
5.With 2 screws removed, just pulling this board out and hold it with one hand.
6.Plug the amp and switch it on.
7.If your amp stays ON forever, the problem is from this long board.
8.If switch off at once, the problem is from power amp board.
Try the above- mentioned steps. If DC protect, write an email to me via searching you tube SR600 capacitor replacement. Don't be afraid.
So many people wrote to me.
If over-current protect do the
following steps
(O)unplug the amp.
(1)download DS-TX494 service manual.
(2)open the amp metal cover.
(3)measure 7 large white resistors resistance loacated next to power transistors mounted on a large heat sink with black probe touching the middle pin and red probe to first/left or third/right pin.
(4)If this 3 Pins large white colour 0.22ohm x 2 resistor is open with infinity ohms ,
(5)replace it and jot down this channel for example left surround faulty. Usually only 1 channel went faulty.
(5a)When the white resistor didn't burn, "2 channels" were damaged due to bad soldering joint of the large white resistor, however.
(5b)When this happened, time taken of shut-down due to over-current is 3 seconds NOT immediately.
(6)the two large power transistors next to this white resistor 0.22 ohms x2 should also be replaced.
(7)plug the amp
(8)switch it on
(9)if ok, troubleshooting get done
(10)if not ok
(11)replace ALL the components of this power amp channel.
(12)pre-amp section no need to check.
remember if not OK, the replaced 0.22ohm x 2 resistor and 2 power transistors maybe shorted again. Check them first. If OK, replace ALL Components in this channel except 0.22 ohm x 2 and 2 transistors. 0.22 ohm x 2 means left and middle pin 0.22 ohm as well as right and middle pin also 0.22 ohm that are 2 pieces of resistors with 0.22 ohm in a large white 3 pins resistor.
Remember sometimes the
0.22 ohm white resistor is normal. If so, use a digital multimeter to measure the be bias transistor voltage via multimeter diode test function. You can compare the normal value,580mV to 650mV with faulty one,3.2mV. And the CE resistance is 1.8ohms only instead of 3 Mega ohms.
Jan 09, 2018 | Onkyo TX-DS494 Receiver
Sharp 17" TV
It's the Closed Captioning function I think. I've had the problem with my Sharp TV (and other TV's that have Closed Captioning function). Look at the menu or the manual to see how to turn off Closed Captioning. It might be marked as "CC".
Oct 06, 2007 | Sharp 25N-M100 25" TV
Starview digital receiver
Did you re installed the channels? If not go to antenna setup and scan and get channels back first. After this you should go to a good strong channel like 100 or 500 and let stand for a few min and it should come back if not then you are down and need reprg.
Sep 16, 2007 | Audio Players & Recorders
My back speakers wont produce any sound
OK I believe there is a small indented "Reset Button" around somewhere on the back of the unit, With the unit powered ON, & using a small diameter implement, straightened paper clip etc, press IN the button and this should "Reset" ya unit. This may indeed fix all your problems as the Unit "Reads" the speakers at turn on.
Aug 08, 2007 | Kenwood KAC-8403 Car Audio Amplifier
Braun Flex Integral 5550 RB Electric Shaver Logo
44 people viewed this question
Top Braun Health & Beauty Experts
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
