Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Spinning problem I have a whirlpool ultimate care II everything its working pretty good but when its time to spin the basket hits all 4 walls inside producing a very loud noise can  I fix this problem ? is there a way to adjust the basket or should I just put only small loads because if I have just half load it spins good
  • hhpeter Nov 10, 2007
    well everything, to me, looks good inside all the springs are attached old is I don't know I found it last week on the side of the road the switch under the lid was broken so the machine wasn't pumping the watter out so I fix it and I tried it yesterday but I guess I put to many heavy clothes like coats, jeans and a thick jacket so the machine when spinning was hitting the walls today I tried with a medium load and everything worked fine
    I found a yellow strap with two steel clips on it it is cut or broken, I don't know, in two pieces anyone have any idea for what is that ?
    Thanks for the answer!
  • 248 Answers
It may have a broken suspension spring. These units sometimes rust out where the rear motor counterbalance spring goes to the frame. Tilt back and see if you see a spring running vertical from the frame inback on bottom near center, up to the mechanism. If it is rusted out, just drill new hole near old one and re-attach.
Also lift rear of washer 4 inches or more by tilting forward and setting back down. This will set the self leveling rear legs, if there not stuck. When you set it down it should not have any movement from corner to corner. Try pushing up and down on corners. It should be pretty steady.
Try reaching inside and moving inner tub back and forth. You should hear a splashing sound. This is the solution in balance ring in top of outer tub. If you don;t hear this it may have leaked out and may need to replace balance ring.
The other thing involves a bit of work. The snubbers may be worn out. How old is this unit?
Posted on Nov 10, 2007
Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
May 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II Washer wont balance
Your basket drive is grabbing. the only way to stop that is to locate the clutch and the tube directly above it is your basket drive put a little white lithium up there. but not in the clutch. this will solve that problem. But if you do not know what you are looking for this will be difficult to locate.
Jan 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II spin cycle not functioning correctly
It sound like the basket is out of balance. When it spins open the lid and see if the basket is moving side to side and back to back. If so look under the deck and see if there is springs or rubber ties attached to the basket.
Jan 19, 2009 | Whirlpool LSQ9665JT
Washer spinning irregular.
your counter balance spring has broken off..onthjob
Jan 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here.
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II GSW9650LWP Top load
sounds like the basket drive. it is kind of a big need to take out the gear case and then the basket drive. you need a special tool to get it out. the agitator comes off forst there is a spanner nut that you must take off.
Oct 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Addl Info: Our Whirlpool Ultimate Care II washing maching agitates fine, but will not spin.
The spin tub mounting block is probably stripped on the basket drive. Remove agitator. Now put machine into spin do you see shaft spinning but the tub isnt moving???
Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle
pull unit out from wall a bit no need to disconnect anything.CAREFULLY tilt unit back and have some one hold for you while you go under unit to check MOTOR COUPLING
Oct 25, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
134 people viewed this question
Dan Webster
Dan Webster
Sal De
