TURN THE FRIDGE OFF AND DO NOT USE!!!! Your cooling unit is leaking!!!! You will need to replace either the cooling unit or the entire fridge. There is usually about a 400 dollar difference in the two. Check your model number and serial number of the fridge and call your local dometic dealer to see if it is under recall. You may be able to have it repaired for free. If you provide me with the model, serial number and serial number of the cooling unit (located in the rear through the door on the tank assembly), I can provide you with this information.
Again, TURN THE FRIDGE OFF and DO NOT USE!!!!!
Let me know what happens,
Jeff
