Question about HP OfficeJet 7410 All-In-One InkJet Printer
Blinking panal lights/no responseno communication w/computer.Help
Good Morning. There was a power outage yesterday. Last night, I found an error code 0x866a7a16 on the screen panal of my HP officejet 7410 All-In-One. I have Windows XP. The PRINT On button,FAX Auto Answer button and Explanation Point button continue to flash. I powered down, changed the USB cable, pressed every button on the panel and get no response. I also tried to remove the print cartridges but they are locked in place. I have power but no responses. Tryed to do a print from my computer and got a message my computer could not communicate with the printer. Can you help me? Thanks. Jan
    Problem Solver:
  • 5 Answers
Hi you can try these steps:
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
  • If the copy job is successful, you do not need to continue troubleshooting.
  • If the error message displays again, proceed to the next solution.
2)
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
  4. Disconnect the power cord from the product.
  5. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
  6. Try making a color copy by pressing the Start Copy Color button on the product control panel.
  7. the # and 6 will reset the whole printer as it is factory, I hope it will work fine!!Best of luck!!
Posted on Jul 04, 2009
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
I have an HP 7280 all in one. Worked great for a couple of years and now I have blinking lights and a code on the screen. The code is B0539F38 and sometimes it is 00729C8. I was able to reconnect it last...
You need to pull the right side panel off, remove the motherboard, pull the coin cell battery out for a couple of seconds, put it back in and back together. Your issue will be solved.
Jul 14, 2011 | Office Equipment & Supplies
Monitor blinking but will not come on
most of the time the blinking is a form of error message from the monitor depending on how many blinks in between each pause lets service technicians know which breaker fuse or transistor needs to be replaced
I would suggest taking it into a computer repair store and have them attempt to fix it however alot of the times its cheaper to just buy a new one
Hope this helps
Robb
Apr 26, 2010 | Dell E193FP 19" LCD Monitor
My Vip622 was down this morning, no power outage,
Unplug the unit from the mains for at least an hour, then plug it back in again and try to boot it up.
Good luck
Jun 19, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Power outage caused by fridge to quit
OUCH! , the partial digit display is an error code that has a meaning and they are never good , these units I have seen/repaired many times but I do not have the code book to determine it.
Try holding down the power freeze and power cool at the same time until you get something. If the unit is ok it will reset and hopefully be fine , if you still get a code these units have longer warranty's and could be repaired with no charge.
Phil
Apr 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
No display
Your minitors power supply is now damaged, probably from the power outage. I t will need to be repaired or replaced. Check the cost and benifits of both options and make a discision.
NSSMS
Jul 30, 2008 | Acer AL1912 19" LCD Monitor
Kd-32fs170
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 24, 2007 | Sony KD-32FS170 32" TV
HP OfficeJet 7410 All-In-One InkJet Printer Logo
136 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
