Question about Rainbow E series Canister Wet/Dry Vacuum
No spinning in the power head
I have Rainbow e series and the wheel isn't spinning at the bottom of the head. The belt is secure/tight and there is suction at the bottom of the wand. What's the problem? Do I need a new power nozzle or wand?
Thanks-
Brent
  • 11 Answers
First, check the red reset button on the power nozzle head. - if it's popped out, push it in. Also, if you have a switch on the handle, make sure you're pressing it while you're vacuuming. if those obvious solutions are already remedied, you may need to check the power outlet on the canister for voltage with a voltmeter while the vacuum is running, and then check your power hose and wand for continuity (checking for a broken wire) while the hose is disconnected from the canister. If all this checks out and the power nozzle still doesn't power on, you may have a bad motor in the power nozzle. If you're good at taking things apart, then it's a simple fix to replace the power nozzle motor.
Posted on Jul 03, 2009
The power nozzle is not working and the belt seems to be in place. The motor is running fine and I can use other attachments
There are a few problems with this head which we frequently encounter.
One, the motor get's clogged up and the brushes get stuck in the motor.
The red top circuit breaker fails, and under load, the motor will stop.
Take the 2 wires off of the breaker in the power head, and short them together to find out once you have cleaned out the motor which will be a mess inside.
The belt if worn will not operate the power head if you put your foot on it and see if the brush spins.
The belt is a major problem as well as the replacement of the motor.
The motors are 45.00 CAD and belts 4.00 Cad.
The yoke on the power head also gets clogged and needs cleaned out.
Try these procedures and I hope all works out for you!
William R!
Feb 21, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Belt no longer turns the brush
JKGonzo:
You'll need to open the vacuum head and remove the beater bar. Clean up the bearings at each end of the beater bar and reassemble the head.
May 25, 2013 | Rainbow Vacuums
The belt on the power nozzle is so tight that it is not turning and the power nozzle won't turn on when you press the handle
Possible bearing in the motor or brush roll is locked up. Check to see if the light comes on. If it does not, then you have an electrical problem but that is a separate problem from the belt being tight. Let us know if you need service....www.rainvac.com
Nov 25, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Power head is spraying out dust. No particles are going into the water
You can check the belt. If you rainbow belt is broken the power head will seem to spit dirt back out.
May 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
The beater bar won't spin
Even though the belt is intact it can still be stretched and if it is it won't turn the brush roll when it's on the carpet. Here is a link to the belt you need and to a manual you can view:
Rainbow Replacement Belts and Manual
Nov 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Power Head doesn't work
Are you talking about the large power head (ised for floors) or the smaller power head (for upholstery)?
If you are talking about the large one the first thing I would check is the belt (accessed by turning the tiny lock knob on the bottom with a flathead screwdriver).
If the belt looks ok the next thing I would check is make sure an accumulation of hair hasn't built up on the ends of the roller....take the roller out and turn the roller by hand holding onto one of the ends...it shoudl move freely....
Jan 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow SE vacuum was working fine until I ran over the edge of a rug and it went in to the nozzle. I immediately switched the vacuum off and proceeded to move the rug. When I tried to turn the Rainbow...
hello lilbutmunch1,
The brush is motor/belt driven so you probably either broke the belt or it shifted off the motor or brush shaft. I suggest you unplug it,flip it over and look for screws that hold the baseplate together.. remove those screws and seperate the baseplate to gain access to the brush and motor head. Once open, it should be fairly obvious what the problem is.. a broken belt, a belt that has shifted or the brush won't spin freely due to an obstruction. Hope this helps..
Regards,
Rick ( bigbutmunch..LOL)
Dec 04, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series
The belt looses it tensile strength (tightness) over time. But it's the part about funny sounds and shutting down that concerns me. If it smells like a tire fire then it's the belt if it smells like plastic and burned hair then the motor has a bad field or armature. Probably one of the carbon brushes got hung up and burned a segment in the armature.
Oct 02, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
653 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
