Question about AOC 917Sw 19" LCD Monitor
What is proper way to clean a 917Sw monitor? - AOC 917Sw 19" LCD Monitor
  • 5,081 Answers
I use a 70% isopropyply alcohol mixture with an equal amount of water. 50/50. Do Not use a paper towel but a clean soft cloth.
or
most comp stores will have special wipes or special cleaning stuff. best to use those as most are anti streak and anti static. water doens't evaporate completely and so you get annoying streaks.
Posted on Jul 03, 2009
I just restored the computer to a month ago hoping I'd get rid of a red tint. It didn't. Now I think it might be a monitor problem. Any suggestions? Earlier this morning , everything had a...
Have you tried replacing the cable first, I had a similar problem with my monitor(only it was blue tint). I would also check and see if the monitors connections are hooked up properly. I hope i could help.
Jun 18, 2011 | AOC 917Sw 19" LCD Monitor
My monitor keeps saying "No signal." I've checked and rechecked all connections and can't find anything wrong. Product number is : 917Sw
When the LCD monitor shows you "no signal" it only means it cannot acquire any feed from your computer. If you made sure all cables are connected properly and tightly, then there must be something wrong with your video card on the computer or the VGA cable itself. To verify is this is a problem with the videocard, then try another monitor, if you have a spare, and see if you can get picture; if yes, then you have a problem with your AOC's VGA cable. Try to twist the cable on both ends as if you are adjusting the wires inside.
Sep 13, 2010 | AOC 917Sw 19" LCD Monitor
I have a zoostorm desktop with aoc 917sw monitor but i get no sound also where do i plug speakers in .
This particular model does not come with any audio connections. It only has a standard RGB D-sub (VGA) connection.
To connect your speakers you will have to plug your speaker's audio cable into the headphone (line out) jack on your computer or laptop.
May 01, 2010 | AOC 917Sw 19" LCD Monitor
Remove banner "input not support" in 19" wide LCD 917Vw monitor. i am working different operating systems development some i try to excute some work this banner will appear pls help me..
You PC video setting is too high for the monitor to support, you need to set the PC resolution to 1440 x 900 @60Hz, try that first. Here is the spec for your monitor: http://reviews.cnet.com/lcd-monitors/aoc-917sw-lcd-display/4507-3174_7-33109821.html?tag=mncolBtm;rnav
Unless there are problemswith the logic board in the monitor if the resolution is already set correctly.
Mar 17, 2010 | AOC 917Sw 19" LCD Monitor
I am getting a INPUT NOT SUPPORT message for my 917sw AOC lcd monitor. It does work on safe mode I am using windows vista, but when I come back to normal mode, I see the same message again... HELP!!!
The resolution selected in normal mode is not supported by your monitor.
Instead of booting into safe mode, boot into VGA mode - this should allow you to change the resolution - change it to one that works and then you should be able to use normal mode.
Hope this helps, Sherwin
Dec 21, 2009 | AOC 917Sw 19" LCD Monitor
AOC 917Sw picture at the start then black screen. Tried hooking it up to another computer and have the same problem.
Your backlight in the monitor is failing.
You can repair it but depending on where you are it may be cheaper to just buy a replacement. Parts cost can be $60-$150 plus labor.
Nov 03, 2009 | AOC 917Sw 19" LCD Monitor
On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Aug 29, 2009 | AOC 917Sw 19" LCD Monitor
AOC 917sw 19 inch monitor resolution issue (same as above)
Have you try the following resolution values:
1280 x 768
Usually its the standard for widescreen view
Please don't forget to rate if answer is useful
Jun 18, 2009 | AOC 917Sw 19" LCD Monitor
19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
Apr 17, 2009 | AOC 917Sw 19" LCD Monitor
AOC 917Sw 19" LCD Monitor Logo
126 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
