Question about Samsung SyncMaster 2433BW 24" wide format TFT Screen Monitor
A single red line on the right side of the monitor suddenly appeared and will not go away.
3 Suggested Answers
SOURCE: A pink vertical line appears suddenly on the screen
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Posted on Apr 04, 2008
budmrtn
  • 11361 Answers
SOURCE: Two bright lines on my acer 17" lcd monitor
You have failed TFT driver in the T-CON board, in other word, nothing you can do to fix it without replacing the LCD panel.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jun 06, 2010
Testimonial: "thx. had to buy another lcd monitor. "
I have Toshiba SATELLITE P105-S6197 Laptop and suddenly a horizontal while/grey lines appeared as a strip and after windows login it appears as a black strip at right side
Sounds like a bad screen. The easiest way to verify that would be to attach this to an external monitor (at work, a friend's ... if you ain't got one) - if the external monitor apprears good then you've pretty much iso'd the problem to your laptop's screen. This model uses a 17" widescreen. Best place to buy 'em would be on eBay, and they'll usually run around $90 to $100 if you need one right away - half that amount if you've got time and patience :-)
Sep 06, 2011 | Toshiba Satellite P105-S6197 Laptop...
LG20" monitor. Suddenly a red
Try to reset it
Scroll through the menu options by using the up and down arrow buttons located just under the "Menu" button. Scroll down to the "Setup" icon, which looks like a big cog. Press the "Auto/Set" button to access the Setup menu. Scroll, using the down arrow, to "Factory Reset." This setting is located at the bottom of the Setup menu. Press the "Menu" button on the right side of the monitor. This will bring up the On Screen Display. If nothing happens when the "Menu" button is pressed, press and hold it for several seconds to unlock the On Screen Display. Press the "Auto/Set" button to choose "Factory Reset" and then press the down arrow to reset the monitor.
Jul 23, 2011 | LG Computers & Internet
Vertical red line suddenly appeared about 3" from right side
Download free Service Source Apple Cinema HD Display 23′ LCD (ADC).pdf (20 pages pdf file, 1 MB). (You have to add a .pdf extension to this file, in order to display this service manual correctly.)
OK that link will get you a a service and repair manual, use this to sort out your problem. Right click on the blue link above, and save as, remember to add .pdf.
May 01, 2010 | Apple Cinema Display 23" HD Monitor
A red line appears down the right hand side of my
dear friend . .
the line appears due to some tecnical fault of your monitor
if u have still in warranty period then just change it soon
Oct 06, 2009 | SNK Cibox Inter@ctive C2201 22 inch LCD...
What can cause a single red line to appear on my laptop LCD screen? It's a small/fine red line appear horizontally (left to right) It's NOT radio interference,back light,broken ribbon cable,or connector...
Thats a generic problem with LCD screens. Its more common in Mobile screens. Sorry, no there is no fix to it other than replacing the LCD itself. Just pray that it shall not grow because as and when the compressed gas from within the LCD will leak the line will be becoming broader and broader. It is caused by damage to the LCD corner Just a hit on side of LCD and a hairline crack for giving way to the encapsulated gas.
Jul 28, 2009 | Computers & Internet
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Thin red vertical line length of screen(right side)
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Feb 20, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Single vertical red line
Hello Monastirion,
Is the red line there all of the time without exception, for instance when you initially turn on your pc, is it there before the operating system boots?
If so, the monitor itself is most likely broken. I would return it to wherever you bought it, if possible.
Regards,
-Chester
Dec 27, 2007 | LG Flatron L1919S LCD Monitor
A single vertical red line
That means the LCD panel itself (the actual glass) is broken. Don't delay, return it and get another before it's too late! The problem will most likely NOT go away, and there is no fix other than to replace the panel itself. The panel, when purchased separately, can cost more than the monitor itself.
Dec 27, 2007 | LG L1915S 19" LCD Monitor
Apr 09, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Open Questions:
See all Samsung SyncMaster 2433BW 24" wide format TFT Questions
Samsung SyncMaster 2433BW 24" wide format TFT Screen Monitor Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
