Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Sister borrowed vacuum. When it came back it was missing a hose from canister to upright part. Where do I find a replacement?
    Problem Solver:
  • 11 Answers
If you go to www.dyson.com , Online Store, Parts & Accessories, DC14 Animal, the "internal hose" sells for $8.99. The Part# is 904219-05. This short hose is located on the underside of the machine. (It is not the main hose on the rear of the vacuum.)
Posted on Jul 25, 2009
  • 5 Answers
If you go onto the dyson website or give them a call they will be able to help. I would ask your sister where it went to first though.
Posted on Jul 07, 2009
Why doesn't my dirt devil vision turbo have any suction through the hose yet there's good suction at the hose connection to the canister?
The hose is probably blocked. If possible reverse it (put the intake of the hose on the canister connection) that should suck out the obstruction. If that fails try to carefully push a broom handle into the hose, preferably from the end that connects to the canister. Put the hose back on normally and see what happens.
May 22, 2015 | Dirt Devil Vision Turbo W/Bonus Upright...
Tip
Bissell Bagless Upright Vacuum not working
If your Bissell upright vacuum cleaner is not cleaning like it did when it was new, then you need to provide a bit of maintenance or service. I will tell you how you can do this maintenance to your Bissell vacuum.
First, make sure that your floor vacuum is unplugged. Then you can work safely on your Bissell bagless vacuum.
If your Bissell upright vacuum is losing suction, then the next thing to check is the canister. It is very easy to simply forget to dump the canister.
The while you have the canister out, check the filter inside the canister to make sure that it is not plugged full of dirt. This filter can be difficult to access, but a little persistence will pay off. When you get the bottom of the cup open and remove the filter, use a bit of soapy water to wash out the filter. You can then reassemble the filter into the bottom of the canister.
On the left side of the vacuum there is also a HEPA filter Bissell has there to help filter the air even more. Remove that, clean it also and replace it.
The hose is the next thing to check. You can completely detach the hose from the vacuum. Check the hole at the bottom where the hose hooks up to make sure the hole is not plugged. Then stretch out the hose and run something like a coat hanger through it to make sure that there are no obstructions inside the hose. You should be able to hold the hose up to a light and see right through it.
The last thing to check is your Bissell vacuum belt. If the belt is too loose it will slip and not spin the brush properly. Bissell belts can be purchased online easily, or in many grocery stores. If your Bissell upright cleaner has a slipping belt, it may also be because of strings, carpet pieces, etc… getting wrapped around the brush. Remove the vacuum brush and cut off everything that is wrapped around it. Always be careful of the vacuum belt after you have just used your vacuum. The belt will be very hot just after use.
These steps will help you to get your Bissell upright vacuum cleaner working like new again.
on Mar 21, 2010 | Vacuums
Vacuum picks up some dirt and debris but not all, and spits some back out?
Some blockage at the pickup or in the hose if it uses one---dirt etc being kicked back out is a clear sign of this----if it has a tube check that first, and if a head with turning brush do not miss looking for a blockage there.
Dec 11, 2012 | Eureka True Clean Upright Vacuum (Yellow)...
How do i replace the hepa filter on a dyson dc18? I removed it and now I cannot put it back on.
It is very simple to change the filter and re-attach the canister. Once you have removed the main canister (the one that has the washable filter) you should see the plastic canister, which houses the Hepa Filter. 1) To make life easy, turn your vacuum around, so you are now looking at the back (where the hose and wand are). 2) Remove the hose and wand as you normally would, if you were going to use them. Just lay it on the floor. 3) Now that they are out of the way, you should see the grey plastic holder, towards the bottom (approx 6 inches above the red release peddle for the vacuum. It is attached to the vacuum with only 2 Phillips-Head screws, and was used to keep the hose in place. 4) Use a screwdriver to remove the screws (one one each side). Once it's removed you should easily beagle to change the Hepa Filter. NOTE: Pay attention to where the 4 inverted latches on the canister are, and pay special attention to the fact that there is an extra latch on the canister, which faces the opposite direction of the others. It is this latch on the canister, which must be located through the back handle of the vacuum, since this was the main latch that was secured by the grey hose piece, which you first removed. 5) To reassemble the canister, line up the clips,especially the one that I just mentioned, and make sure the canister is flush against the base. 6) Now, reattach the hose securing piece that you originally removed, and the Hepa Filter and plastic canister should now be fully secured. 7) Place the hose and wand back into their original position and you should now be ready to vacuum. I hope this was helpful. S.I. Educator
May 29, 2012 | Dyson Slim DC18 All Floors HEPA Bagless...
Vacuum has lost suction and is making a hissing noise
I had the same problem with my Kompressor.Initially I had cleaned all three removable filters.There is two in the canister that can be washed with dish soap. The HEPA filter is located in a compartment on the lower front side of the vacuum.This HEPA filter should not be washed.I found that tapping it inside a trash can dislodged alot of dust from it. After cleaning all the filters and canister I was having the same hissing noise coming from a small hole near the bottom of the vacuum. Next I removed a hose fitting on the lower back of the vacuum and that is where I found a very large amount of debris clogging up the hose. I used a metal coat
Nov 11, 2011 | LG Kompressor Upright Vertical Cyclone...
Dyson Animal, purple ball, no suction upright
you might be missing a blockage in the hose from the brushes to the dust collector Take apart the hoses and check
Jul 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vacuum comes on and make loud noise but will not **** anything up
the vacuum is clogged either the hose or the canister. turn it upside down to unclog it if its in the hose, take the hose off and turn it around and put it back until your hear the suction sound like a big thump, then put your hand to cover the hose and feel if the suction got stronger, then replace the hose, if rhat doesnt work find something to push the clog thru the hose and periodically put the hose in to suction the clog out.
Sep 26, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Cloged, will not pickup Hose also cloged no suction
Generic problem for all Vacuums
Clogged, will not pickup Hose
Clogged, will not pickup Hose also clogged no suction
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I’m not sure if you have a canister or an upright but there are thing you can check on both machines, canisters – you can check the suction from the end of the hose and work your way back to the canister, start with the end of the hose, then remove the hose and check the suction on the vacuum – most clogs are in the hose – if you have a hose clog run a steel ball thru the hose to see if goes thru all the way if it does than check the bad and the filter, if those are ok you may have a bad motor. If it is an upright, make sure the height adjustment is correct and is adjusted correctly, then use the steel ball and run it thru the attachment hose to see if that is blocked or clogged. Then check the belt and the extension wands to see if there is a blockage there as well, if you have good brushes and the tone changes from high to low and the brushes are actually hitting the floor, then you may have a motor problem and then you might have to replace the motor or fan assm. I hope this was helpful.
Apr 21, 2008 | Vacuums
No suction
No suction
no suction
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
110 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
