Question about Whirlpool LER5636P Electric Dryer
No heat where is the heating element on a dryer
  • 5,911 Answers
If this is a Whirpool model dryer (this includes Kenmore, Estate and Roper), the heating element will be located on the lower right hand side with the back panel removed. If the dryer does not have removable back panel, the heating element will be located inside the dryer under the drum on the right hand side.
Since you posted no brand name or model number, I'm going by the heading you posted this under. If your dryer model is different, please post back with your correct information so that I may assist you better.
If you have questions, please let me know. I hope this answers your question.
Posted on Jul 07, 2009
Does not heat up
what type of dryer rate these
Open The Cabinet
  • Unplug the dryer's power cord from the electrical outlet. Remove the toe panel by inserting a putty knife between the toe panel and the front panel. There are retaining clips 4 in. from each corner. Slide the putty knife blade over each retaining clip and pull the toe panel away from the dryer.
Test the Heating Element
  • If you own an electric Whirlpool dryer, locate the heating element. The heating element is the workhorse of the heating operation. The heating element is most often inside a can. The thermostat mounts to the side of the heating element can in most Whirlpool dryers. The thermostat looks like a small oval part with two wires connecting to each side.
    Pull the two wires that connect to the heating element terminals. Set a volt-ohm meter to the RX1 scale to check the continuity of the heating element. Clip each probe from the volt-ohm to each of the heating element terminals. A good element will give you a reading between 8 ohms and 12 ohms. If you get no ohm reading, the heating element is faulty and you will need to replace this part.
Jan 15, 2013 | Dryers
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Tip
How to Replace Heating Element from a Maytag Dryer?
The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.
2) Locate the vent hose on the rear of the dryer and disconnect this hose from dryer unit.
3) The hose is mostly fixed in a metal clamp and the metal clamp is fixed by the screw. Loosen the screw and remove the clamp and remove the hose.
4) The heating element is located in the cabinet.
5) In some models the cabinet is located at the rear of the dryer. And in some model its located in the front of the dryer.
6) Locate the heating element cabinet and remove the screws holding the cabinet.
7) You will see the heating element now. There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.
8) Remove the connector carefully from heating element with the help of needle nose plier.
9) After the wires are removed from heating element’s terminals. Remove the screws holding the heating element.
10) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
11) Remove the old heating element and insert the new heating element.
12) Connect all the wires as it were connected before.
13) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
How do i change the element on a samsung dryer
Hello.
When the dryer just isn't getting your clothes dry anymore, the culprit is usually the heating element. The dryer part may look intimidating, but you can replace the heating element.
Step by step instructions
TOOLS NEEDED New heating element,Screwdriver, Needle-nose pliers.
1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
4 Unscrew the screws holding the element in place and pull it out.
5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Thanks.
Sep 26, 2011 | Dryers
Quit heating
Hello there and thank you for choosing fixya
ok there are a few reasons why this happnes i will post them below for you
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Jan 22, 2011 | Dryers
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
Heating element is out.
Instructions Things You'll Need:
  1. Step 1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Step 2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Step 3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Step 4 Unscrew the screws holding the element in place and pull it out.
  5. Step 5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Step 6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Step 7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Dec 01, 2009 | Kenmore 62602 Electric Dryer
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
368 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
