As far as i can work out, an Error Code 007 on the Canon IR 2022 photocopier means there is a problem with the "Fixing Assembly".
To reset the code hold the * key then press 2 & 8 keys at the same time.
If it reoccurs then possible reasons for the error are a torn sleeve in the mechanism or the film roller is not working. To fix means disassembling the fixing mechanism. If it is a ripped sleeve then replace it. If it isn't then try greasing the roller mechanism.
Just to note that it is maybe a good idea to clean the all the temperature sensors with ethyl alcohol while you have the unit apart.
SOURCE: Error E007 canon IR 2016
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
To clear the error, execute the following in service mode: -
COPIER>FUNCTION>CLEAR>ERR.
to open service mode press star press 2 and 8 key same time then press star again.
Is there a fault in the fixing film edge rotation detection mechanism?
YES: Replace the fixing film unit.
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
SOURCE: My canon iR 2022 is
Canon fuser technology is hp laser printer system.This copier has a fuser film or eleventh cover.Some times its torn or short then this machine say E007.Its an error code.When occurred this E007 you should defective film.
SOURCE: canon irt 2022 says "system error 007"
dear sir !
my canon ir2022 has one problem which is system error E007 how i can solve this above problem , i am wait for your answer .
Thanks & Regards.
Nayeel
