Question about Polaris Pb4 - 60 Booster Pump
I just replaced the motor bearing and after putting the whole thing together the water is pouring out of the front
    President:
  • 1,378 Answers
Replace the mechaical seal and volute o-ring. Parts are available locally or try our website at www.arrowpools.net
Use the contact button and include your pump model number to receive a parts breakdown and pricing.
Posted on Jul 04, 2009
Hi y'all. LG WM3677HW It was making a bit of squeak while tumbling, and just a hint of play in the drum when pressing up at the front. I took a look today, and there id a brown rusty-color stain in...
You literally have to take that whole assembly out and knock out BOTH bearings. You have signs of water leakage common these units caused by washing stringy things- worn fabrics that threads are loose, or sometimes long hair! This causes the shaft seal to fail. You'll need to inspect the shaft, it MUST BE ABSOLUTELY SMOOTH! Replace the seal and bearing and it will sound like new again. Be careful not to damage the coils!! (called "Motor") If you do, you can damage the electronic driver.
Feb 04, 2018 | Washing Machines
I have a LG model no LD-2040WH dishwasher that is troublesome at the moment. During the washing cycle, it gives a very high pitched screeching noise. It has now displayed an error code E1. I have take
The problem could be the washer motor bearing. LG motors have the impeller unit coupled to the motor and the water seal between the motor and impeller is a problem. The drop of water that leaks ends up on the bearing and it eventually gives problems. This can be seen by close inspection of the front bearing for slight rust indications .They use poor quality bearings but replacing the bearing is easy BUT you need to replace the water seal as this is the cause of the problem. Unfortunately the water seal is part of the plastic impeller unit and must be replaced. Not necessary to replace the whole motor as the bearing is easily replace and cheap. (the noise made by this fault is more of a slightly high pitch grinding / whine)
Jan 18, 2015 | LG Dishwashers
I am getting a buzzing noise from my electric motor. i tried changing the capacitor but still no change. The motor starts up sometimes but starts making a noise.Isusupect the winding or a bearing in the...
First thing you must check the machine with load, without load with water fed, and without load with no water fed. Then check the simpler cause. See if the cooler fan is hitting the casing.
If you check machine without pressure load and without water and still buzz...then the motor has a bearing fault or other fault.
The head of the pump can be removed from the motor. Carefull because as you remove you will have the springs of the pistons pushing out. Now under the pistons and complete head you find "Oil". Remove this oil and you find a thrust bearing. Remove bearing by hand and you see a plate..held by a screw(most cases). In my opinion I always send the motor to a winder, even for bearing replacement. But if you know how to replace damaged bearings..go ahead. One small thing..if you have a chance, try the motor on its own without the head( this is tecnician work)...if it still buzz..it is for sure the motor. Also it is wise to check the pistons at the head. If these are scratched or damaged and stuck...they will also have caused unnesessary load on the electric motor. When putting back all things together it is wise to replace all seals.
Fulltech.
Aug 02, 2010 | Karcher PSI Electric Pressure Washer
Need direction on replacing the front hub assembly on the front passenger side
It's a press-in bearing. If you don't have the tools to press the bearing, you can still save some money. Here's what I did:
- Drain transmission oil,
- Remove front right wheel,
- Remove brake caliper, pads, caliper hanger,
- Remove the wheel speed sensor (even if no ABS),
- Remove the two large strut bolts (100+ lbs ft/lbs of torque),
- Remove the ball joint nut,
- Remove the ball joint from the steering knuckle,
- Remove the axle from the transmission using a pry bar.
Now you'll have the axle, steering knuckle, wheel hub and brake rotor removed from the car, and it'll all be ceased together. Bring the whole thing to your favorite mechanic and get him to separate all these parts and to install the new bearing in the steering knuckle. It'll cost about $100.
Now you'll have the axle, steering knuckle with new bearing and hub installed, and the brake rotor. Take these parts home and put the car back together in reverse order.
Seriously consider replacing the axle while you're at it.
Nov 17, 2009 | 2003 Hyundai Tiburon
Front bearing need to know how to replace
The bearing in pressed onto the hub. Remove the wheel, remove the cotter pin and the great big nut on the axle stub. The whole shebang, bearing and hub, should slide off with a little gentle persuasion.
Take the assembly and the new bearing to somebody with a press and have them r&r the bearing.
Put it back together, have a cold one.
Sep 03, 2009 | 2004 Dodge Neon
Replacing front wheel bearings on a 1999 honda accord
there is a hub and a bearing assembly...usually you need to press the bearings into that hub...need a press to push out the old and press in the new...i replaced mine last year by going to the junkyard and taking out the hub and bearing assembly and just putting the whole thing into my car...much simpler..plus you learn how it goes together by taking it out in the boneyard..no press needed...plus if its genuine honda parts from a honda..(you can match the markings) its likely to be a very good part for a long time. Being used isn't always a bad thing as far as honda parts are concerned.This is from my own experience hope this helps you.
Mar 12, 2009 | 1999 Honda Accord
Very noisy when it spins out
the spin surport and the back tub bearing ,defective,,shot,,bout check your owners manual your under warranty,,lifetime on spin basket...onthejob
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag atlantis will agitate won't spin
I had the same problem with my Atlantis a couple of months ago. It turned out to be the bearing for the tub drive pulley. When you look under the washer there are three pulleys. The one for the motor is ont he left, the drain pulley on the right and the big one in the middle for the tub. What I found is that when the bearing went bad, the tub would fill and turn for washing, but it would not turn at all for spinning. I could turn the pulley by hand but the tub refused to budge. I removed the main pulley and could see that the bearing had exploded. You can't buy just the bearing but the whole pulley kit is like $35 so I got off easy. I put the machine back together (which is tricky) but it works fine now. The pulley kit comes with complete instructions but it's really straightforward. The tricky part is that you have to pull down on the end of the drive shaft in order to get the retainer ring onto the pulley. That can be difficult if you don't have a lot of room to work or have a partner to assist. You can replace the whole thing or just the bearing and save the pulley for a rainy day if you want. I opted for the whole replacement. But I saved the old. cause ya neva know!
Jan 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Minn kota turbo 35 27lb thrush trolling motor
I have a minn kota turbo 35 27lb thrush trolling motor after 3 hours of running it the motor dies
Mar 01, 2008 | Minn Kota GPS
Main Drum Bearing
Rear Main Bearing is bad, Believe you have replace whole back of the drum, about 200$
May 16, 2007 | Frigidaire GLTF1670A Front Load Washer
Polaris Pb4 - 60 Booster Pump Logo
293 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
