Question about Hitachi 43UWX10B 43" Rear Projection Television
Hel whit mi hitachi
I replace the stk it muve the lines the cross is ok is completly white but when the tv image apears the combergence is not ok, i want to know the parameters for the tecnician comvergence. thanks for your help
  • 1,694 Answers
Re: hel whit mi hitachi
Remove speaker grill cover on tv lower front.Remove access panel.
Locate small blue push switch = activate convergence grid,then
use 2 & 8 , 4 & 6 , and enter along with adjuster arrows if I
remember right, then magic focus last..............T.
Posted on Nov 10, 2007
0 characters
3 Points
The colors are not aligned blue image shadows
hi ,thats is your convergence circuit is defect,you got 2 integrated circuit call
STK 390-xxx the ic # are depend of the tv chassis model number,
they got to be replace whit new one/ the component arround the ic like resistor ,capacitor
and some time 2 transistor for the minus 25volt,and plus 25 volts
some time you replaced just the stk ic and its ok,anyway taht have to be trouble shoot
if you know a good tech its will be better, or if you have some experience whit this ok
that is an hour job about to verify the circuit component near the ic like some low value resistor
.thats all i can do from here....
hope that give you an idea and have a merry christmas
regards : Alan tech for hitachi ...
Dec 23, 2010 | Hitachi Projection Televisions
Blue and Yellow ghost image overlying picture.
Replace both of your STK ICs STK392-110 use 150s
Mats has them 1-800-628-1118
May 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
My 57twx20b rear projection tv appears to have 3 images that are not aligned I have been advised it is called convergance failure and the IC's called STK's need to be replaced. What are STK's and how are...
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Jan 30, 2010 | Hitachi 57TWX20B 57" Rear Projection...
Blue line Ghost Image on Panasonic Projection TV
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This set uses two Stk-392-110 convergence IC chips; both need to be replaced along with any of the 2.2. ohm light blue resistors around them; a bad resistor will be white in the middle; You can buy both for less than 13 dollars plus shipping on Ebay.
The chips are located on metal heat sinks with fins and are side by side. They are black(about 2 inches wide by 1 1/2 tall) and should have the STK-392-110 number printed on them in white.
Depending on your level of skill at this kind of work you may be able to do it yourself---if you need step by step instructions contact me---I have them in Microsoft word---start to finish repair including what you will need to do it.
If you are not able to do the repair yourself now is the slow time of year for TV repair shops----It should be fixable right in your home and the repair takes about an hour--I have done hundreds of these sets--some shops charge 300-400 but I do lots of them for 200-250 total cost. Make sure whoever you get changes BOTH of the chips!
Shop around and if they say "needs to go to shop" keep looking; any good tech can do this right in your home.
I do this here for free so if this helps you give me a vote here. If you need direct help contact me.
Aug 27, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Hitachi 50 inch projection tv
Convergence ICs replace them bot 2 big black ics STK392-560s not sure what your STK numbers are but use same number to order parts call Electronix Parts 1-800-223-3205 PS if they are using 110s use 180s if 020s use 040s better ics.
Dec 19, 2008 | Hitachi 46F500 46" Rear Projection...
Blue color doesnt muve up
hi there. sounds like a bad convergence IC. possibly a broken connection(s), parts are located on a large heatsink near the center of the main chassis, part number is STK391-110 for standard definition and STK391-570 for high definition, the location and part numbers can vary from model to model and year to year. hope this helps.good luck and be safe.
May 26, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Problem continued
Good Day;
When you activate the Mj focus the TV is restoring the data from the TV's digital circuits. So, you have the ability to change the IC's you can do this.
You need to go into the con service mode. Take off the front grill, remove panel, 6 - 8 screws. From the front there is a switch on the left hand side, it is small, white button with TV on. now you are in the service mode, using TV's remote adjust. Make sure you save dat. Go hit on line site get more info.
Goo0d Luck!
May 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
3D image
you have to replace all 3 ic's and 2 are stk 392-110 and the 3rd one is stk 392-150 they are located on the extreme right of your tv on a long heat sink all 3 are located there.You can get replacements as well as free tech online support at
Apr 10, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Hitachi tv color will not line up
Convergence repairs run 300-400. Electronic parts called IC's
will need replacement.Skill level moderate to high needed.
Part # Stk 392-110  X 2
Mar 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
44 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
