Question about Kenmore Kitchen Ranges
How long does the oven take for the self-cleaning cycle?
  • 5,081 Answers
Most self clean cycles take 4 hrs.The oven is gradually heated up to 950 degrees F which takes up to 1 hr and after the 4 hrs is up it takes some time for the oven to cool down before the door will unlatch at below 550 degrees. You can self clean your oven 2-3 times for the price of a can of oven cleaner and without the elbow grease involved. You should not use harsh oven cleaners on the soft porcelain on your oven liner or it could be damaged. Before you put your oven into self clean you should wipe out any excess spillage with a damp soapy cloth and after cleaning you wipe away the ash with a damp cloth. If you do not want the oven racks to take on a blueish to ugly gray tint do not leave them in the oven during the clean cycle.
please rate my answer
Posted on Jul 03, 2009
3 Suggested Answers
SOURCE: whirlpool accubake oven will not heat after self clean cycle
I had the exact same thing...thermostat..
Posted on Jul 11, 2009
philbran
  • 242 Answers
SOURCE: After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Posted on Apr 14, 2009
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Hi lost the manual..need to start self cleaning
    An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
    Step 1 - Setting the Self Cleaning Mode
    Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
    Step 2 - Cleaning Cycle
    Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
    Step 3 - Automatic Door Lock
    When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
    Step 4 - Removing Residual Ashes
    Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
    Hope this helpout
    May 17, 2011 | Ovens
    How do I clean a self cleaning oven that has never been through a self cleaning cycle and I have been trying to clean it as a normal non self cleaning oven?
    Self cleaning ovens work by getting very hot and burning off spills from their inner coating. They are designed to be very resistant and should go through a cycle happily despite the cleaning products. If you've used anything harsh you wont want to be around (or your pets) while the fumes burn off- that'll take a cycle.
    Sep 11, 2010 | Whirlpool Ovens
    After self-clean cycle oven door won't unlock
    your lach might have given out on self clean. change it
    Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
    Using the oven self cleaning cycle to clean drip
    This is not advisable because it will severely damage the chrome and or color of the drip pans and the oven racks. It will make the oven racks hard to pull in and out of the oven once the finish has been burned off. I did this, so I know.
    Nov 11, 2009 | Kitchen Ranges
    I have never used a self cleaning oven.i have already put oven cleaner on the inside and let it stand for awhile is this right? god I don't want to blow up
    You DO NOT use a oven cleaner with a self cleaning cycle. Wipe out the oven cleaner as instructed on the can. Oven cleaner is better than self clean cycles anyway. Most self clean cycles eventually cause oven control problems.
    Oct 08, 2009 | GE JGRP20 Gas Single Oven
    How do I use the self cleaning functions - kitchenaid oven
    Please allow me to help you first with some background of self cleaning functions:
    Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
    If baking spills are not wiped up after baking, there may be some smoke during an oven cleaning cycle. It is a good idea to remove any pets from the area when running the oven's self-cleaning cycle. There have been reports of oven-heated Teflon-coated items releasing odorless fumes deadly to birds.
    Self-cleaning ovens have the added benefit of more insulation, which helps the energy efficiency for regular baking. This is similar in concept to an increased R-factor for home insulation.
    You will also save energy costs by using the self-cleaning cycle right after baking, to make use of the already partially heated oven.
    Please check this website mentioned bellow which would give you a detailed method of how to perform it:
    http://cleaning.lovetoknow.com/Self_Cleaning_Oven_Instructions
    Hope this would help you .
    God Bless.
    Jul 05, 2009 | KitchenAid Kitchen Ranges
    Self cleaning oven won't start self clean mode
    NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
    Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
    Self Cleaning Cycle for Oven
    I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
    May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
    Kitchen Ranges Logo
    2,669 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Sal De
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
