Question about Kodak EasyShare V550 Digital Camera
Most of the screws holding the faceplates on have fallen out.
I am missing 6 screws. Where can I get replacements?
  • 300 Answers
This seller can help you - http://myworld.ebay.com/elmira.lv
Posted on Jan 14, 2010
The metal wire attached to red bar has fallen out ofhole and wont stay when put back in maybe missing a screw not sure
Look around for a screw hole. Mine has a plastic clip to hold it. You m may be able to just tape cable to handle.
May 30, 2012 | Garden
Want to remove my hard disc... but.. I can get to and remove the 2 screws on the "inside" of the drive.. but.. the two screws next to the case are so close to the case I can't get to them. Am I missing...
The hard drive is secured to the frame and this frame needs to be removed to get access to all the screws holding the hard drive to the frame. The frame may have screws holding it to the case or accessed from the front of the computer after you remove the front faceplate panel.
Sep 25, 2010 | Gateway 510 X PC Desktop
2 discs stuck in console
WOW!!! I am so sorry that this happened. Nintendo products are really hard to open. If you cant wedge the game out with a small screwdriver, dont worry about the game, here are the directions on opening it. Just copy and paste to word so you can see the whole thing easily.
How to open your Wii Console Step by Step Instructions
To disassemble:
  1. Flip the device upside down and remove the small silver Phillips screw. Once out, remove the battery tray from the console.
  2. Next remove the rubber foot directly above this battery tray. Also remove the three square white stickers from the bottom of the Wii. The rubber foot and the sticker are covering hidden screws. Figure 3 provides a shot of where these screws are located. NOTE
    Hiding screws under stickers and rubber pads is a common method used by electronics manufactures to help increase the aesthetics of their devices, as well as prevent people from easily locating screws and taking apart their products.
  3. Unscrew the two Triwing screws and three Phillips screws from the bottom of the Wii.
Figure 3 - Bottom Screws
  1. Flip the Wii over onto its right side. Locate and remove the two rear rubber feet and the two rectangle stickers near the faceplate.
  2. Remove the two silver Triwing screws in the holes and remove the two black Triwing screws on the faceplate (Figure 4).
Figure 4 - Left side screw locations
  1. Flip the Wii upright and carefully remove the two socket covers. They come right out with a little wiggling.
  2. Remove the three black Phillips screws from the black plate (Figure 5). Note the one closest to the faceplate is the longest and will need to go back into that hole when putting the Wii back together.
Figure 5 - Top black plate screw locations
  1. With the screws removed, carefully pull off the faceplate of the front of the Wii. You will need to disconnect the red/black wire plug from the Wii to remove the faceplate completely. Figure 6 shows what is hiding under the faceplate.
wiifig06.jpg Figure 6 - Under the Wii faceplate
  1. Remove black plate from memory/controller socket area.
Remove two silver Phillips and two silver Triwing screws from memory/controller socket area (Figure 7). wiifig07.jpg Figure 7 - Topside screw locations
Lay the Wii on left side (with the ATI and Nintendo logo facing you) and slowly work the right side cover of the console off the device.
This will take a little bit of force. If something appears to be stuck, double check to ensure you removed all the screws.
Locate and remove four screws holding DVD reader in place. Two are located in plain site in the middle of the unit. Two are located near the front of the Wii inside the DVD unit (Figure 8). wiifig08.jpg Figure 8 - The insides of the Wii
Slowly tilt the DVD player upward toward top of Wii. There are two wires that need to be disconnected before you can safely remove the DVD unit. One is a plug type of connector that only requires a little tug. The other is a circuit strip connector that requires you to lift the brown catch, which will release the pressure holding the strip in place (Figure 9). Do not break this!
May 11, 2009 | Nintendo Wii Console
My analog stick is stuck in the upwards direction. Every time I play a game, the character in the game always moves up and in the game menus, the highlighted option always keeps moving up. I really don't...
Sony is full of it. Yes you can repair it. All you need is a brand new nub (joystick). You can find it on the net for about $5 less shipping depending on your model it is not hard to replace. On a phat (old school psp there are seven screws holding the faceplate. Once the faceplate is off there are two screws holding the nub in place. The slim is almost the same there is seven screws holding the faceplate but the only difference is the last two screws you have to take off is on the top. And once the faceplate is off it's the same two screws holding the nub in place. Replace and screw back in.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Console
Display issues with Aiwa CDC X207
I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
I purchased them from Union Electronic Distributors:
https://www.ued.net/ued/addItems.do?itemCode=SNYU0087654U
Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
1) Remove the faceplate from the radio and bring it to a well-lit work table.
2) Remove the four Phillips screws on the back on the faceplate.
3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
7) Solder the new bulbs in place. They are not polarity sensitive.
8) Trim off the excess wires.
9) If you installed the two screws in Step 4, remove them.
10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
Hope this helps.
Ron
Dec 13, 2008 | Aiwa CDC-X204 CD Player
Need to replace faceplate for nokia 5300
Start by removing battery. Then remove the camera plastic panel. After that you will need to loosen the screws holding the faceplate in on the top. You will require a special tool for this but it can be purchased from most places that sell DIY faceplate kits.After careful prying the faceplate should come loose. Keep in mind that the screen over the LCD screen is taped on and will need to be removed separately.
Oct 24, 2008 | Cell Phones
How to remove center console faceplate?
after looking around the edges for small screws gently start prying around the edges at the corners first. the best option is to have your new cover plate in hand and u will see exactly where the snap clips are at and then you can "Gently" pry at those spots with a flat screwdriver to pop it off with
Jul 19, 2008 | 2005 Chevrolet Equinox
Screws Missing
Same issue here although there has not yet been any effect on function. I do quite a bit of underwater photography and the images have remained very good without the screws.
The parts people at Pentax Imaging in Golden Co were very friendly in offering a free set of screws when I called.
http://www.pentax.com/subsidiary.html#n_america
Cheers
Jul 12, 2008 | Pentax Optio S5i Digital Camera
Disassembly to replace LED burner indicator
I'm not an expert, but I just had mine apart. You should take the panel off from beneath the control panel. This is a matter of removing about 6-8 screws and slipping the small piece of sheet metal out. You may then be able to find your "missing" LED, which is probably dangling inside the control panel assembly area. I believe there is simply a tab or other simply fastening clip that you slip the LED back onto; this holds the LED against the control panel. Assuming the LED is still working and still wired to the knob, it should work fine.
May 31, 2007 | Dacor Epicure ESG366 Gas Cooktop
Kodak EasyShare V550 Digital Camera Logo
62 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
