How do I take apart the cabinet on small 12 inch TV
  • It doesn't seem it should be that hard - I think there is a trick to it. I have removed the obvious screws
  • The TV I think just needs fuse as it shows no red light at all when connected to power.
  • I had been away for 3 months and on returning pressed the remote and a static like charge occurred with a "pop".
  • Its about 9 years old , very little use.
  • Reac 12" Colour TV CT-M341MkII
  • 3 more comments
  • jabconsl Nov 10, 2007
    That should be TEAC Colour TV CT-M341MkII
    Solution 2 was my comment sorry hadn't logged in
  • jabconsl Nov 15, 2007
    The top photo is the rear lower area. Any more ideas would be welcome . You can see I have the top partly opened
  • jabconsl May 09, 2009
    Doh eventually found two hidden screws but chucked it out anyway as it wasn't worth repairing
  • 42 Answers
Is there a hidden screw under a lable or nameplate? Sometimes if there is no screw it needs a good "pop" to get it open as they used alot of plastic snaps to hold things together.
Posted on Nov 10, 2007
  • Neil Ulrich
    Neil Ulrich Nov 10, 2007
    Got any pics of the rear lower area?
Hinge cord broken. Need to pull dishwasher out of cabinett
Remove front screws holding washer to cabinet. Jiggle, leveling feet may be stuck
Sep 15, 2012 | LG Dishwashers
My 1978 Suzuki 550 SE starts up with the choke, warms up, and then gives me about 12-15 minutes. It stalls out, then will only restart if I choke it. I noticed that the gas line MAY be crimped, so I took...
That is indeed most likely a stick float.
A percussive type repair may do the trick here.
(hit it with something hard)
My favorite knockometer set for this purpose is a wooden dowel (1/2 inch or more in diameter) placed against the float bowl, coupled with a lightweight attitude adjuster (hammer).
A few short raps usually will do the trick.
Be careful - those bowls are aluminum, and you don't want to break them!
Hit it like you are STARTING a nail, not driving it into the wood (if you get my meaning)
A bike of that vintage does not surprise me that it only starts with the choke.
If one cylinder is flooding, it also doesn't surprise me that it bogs and fails shortly after!
If the percussive attitude adjustment doesn't solve the issue, you'll have to at the very least take off the float bowl and clean or replace the float needle or fix the float itself.
Jul 25, 2011 | 1982 Suzuki Gs 550 L
Any advice or tricks to removing the top of my Kenmore Dryer for belt installation? I've already removed the control console. there seems to be some sort of clip I need to figure out. Kenmore...
on front side of cabinet between top and front, in that seam about 2 inches in from each side is a clip.  i use a paint scraper to wedge in there on each one and it will pop open for you.
Jul 30, 2010 | Kenmore Dryers
How to replace belt on tricity bendix aw440 washer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Oct 12, 2009 | Tricity Bendix Washing Machines
Screen Removal - Mitsubishi WD-62527
Pull the SPEAKER-GRILLE away from the cabinet to remove.
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
Aug 01, 2009 | Mitsubishi WD-65735 Television
Samsung 170 MP LCD Monitor Disassembly
The plastic case also has latches along the sides, top and bottom. Take a small flat blade screwdriver and go between the 2 halves of the case. The 2 pieces should open just a bit, now move the screwdrivers along the seam between the 2 halves. about every 2-4 inches there is a clip that needs to be released. You can release it by applying a small amount of pressure by each clip and moving down to the next one while pulling the case apart.
Corporate Compuer
over 21 years repairing PCs and printers
Jun 17, 2009 | Samsung SyncMaster 17" TFT LCD Monitor
Replaceing cabinet on kenmore top load washer
unfortunately your going to have to pull machine out and loosen several of the small 5/16 bolts or they could be 1/4 inch bolts to get the play u need for the alignment. Cheap fix give it a try
May 03, 2009 | Kenmore Elite HE4 Electric Dryer
HITACHI 65XWX20B - How to disassemble the cabinet?
The 65XWX20B comes apart in 2 pieces - there is a top half and a bottom half.
- The bottom half houses all of the electronics, projection lenses, etc. It is very heavy and should be moved with care.
- The top half is basically just the screen.
I have moved this Television multiple times, even up and down from a 3rd floor apartment!
- First remove the screws holding the top and the bottom, the important ones are on the sides of the TV.
- This is important, I suggest 3 people do this part: Slowly lift the top away from the bottom half of the TV, but -not- very far. There is small wiring harness that that attaches the top of the TV to the bottom to a circuit board. This must be unplugged by one person while the other 2 hold the top half of the TV slightly above the bottom half. Note carefully where this plugs in so that you can reassemble easily.
- Once this is disconnected the TV is much easier to move, although still quite heavy and bulky. Do not turn the TV on its side - keep it upright while moving.
Reverse this process to put it back together.
Once you have done it once it is quite easy.
Good luck.
Jul 29, 2008 | Hitachi Director's Series 65XWX20B 65"...
COld Solder/Short
The silver box where the cable plugs into is the TUNER,there are no fuses in there and the problem is not likely to be there,the loose conection could be anywhere but you have a few places to check,with the tv unplug from the wall you can safely check for loose conections in the power supply area and around the output transistor including the areas of the horizontal drive circuit and output transformer,those are the areas most likely to the symptoms you have but you can also check the edges of the chassis for a broken or crack board.Let Us know if you need more help.Be careful when you are checking for conections.
Oct 15, 2006 | Toshiba CZ27V51 27" TV
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
