Question about Asrock 775i65GV Motherboard
Chaintech 7NIL1 power pin configuration
I have a 7NIL1 and I noticed that the network controller had a bad driver. I forgot what motherboard I had so I took it out and inspected it. When doing so I unplugged everything. Now I cant get the computer to power on because I dont know the pin configuration for the power/reset button. Ive tried everywhere online but cant seem to find it. Any help would be greatly appreciated
  • 104 Answers
Http://www.asrock.com/manual/775i65GV.pdf
This will help you with that.
Posted on Jul 03, 2009
Mother board manual for Chiantech VNF4 Ultra
http://www.motherboards.org/mobot/motherboards_d/Chaintech/VNF4%2BUltra%2BZENITH%2BVE/
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Motherboard installed in computer case, (Processor to the Top, Ram Memory slots to the Right), the Front Panel header is at the Bottom/Right corner,
http://img.neoseeker.com/v_image.php?articleid=1773&image=24
Black rectangle of plastic with 17 contact pins. Top row has 9 pins, Bottom row has 8.
Notice that the Bottom row has a White triangle pointing to the first pin.
This triangle points to Number 1 pin.
Top row has 9 pins.
Starting on the LEFT side going across to the Right;
Pins 2, 4, 6, 8, 10, 12, 14, 16, and 18.
Bottom row has 8 pins.
Pins 1, 3, 5, 7, 11, 13, NO PIN, and 17.
A) Pins 1 and 2 are for the Green Button. This is also the Standby button.
Let's discuss this for a moment............
Myself I wouldn't connect to it.
B) Pins 3 and 4 are for the HarDDrive activity LED.
(Light Emitting Diode, so to call it an LED light is redundant)
Pin 3 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
C) Pins 6, 8, 10, and 12 are for an internal speaker. Used so the computer can generate BIOS Beep Codes.
Doesn't indicate which pin is for the Positive ( + ) wire, but with most motherboard speaker setups, Pin 6 would be for the Positive ( + ) wire, and Pin 12 for the Negative ( - ) wire.
D) Pins 5, 7, and 9 are for the Power On LED.
Notice there are 3 pins. This is used for a dual color Power On LED light.
Usually a Green/Yellow.
Pin 9 is for the Positive wire.
Two wire Power On LED? Positive wire goes to Pin 7, or Pin 9. I believe both to be a Positive connection.
Pin 5 I believe to be the Negative connection. ( - )
(I suggest connecting the Negative wire to Pin 5. Then connect the Positive wire to Pin 9. Not very bright? Put it over to Pin 7 )
E) Pins 11 and 13 are for the Power On switch.
F) Pins 14 and 16 are for a Reset switch, IF a Reset switch is used.
G) N/C for Pin 17. No Connection.
H) N/C for Pin 18. No Connection.
Here's the full review starting from Page 1 detailing the motherboard,
http://www.neoseeker.com/Articles/Hardware/Reviews/vnf4ultra/
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 27, 2012 | Chaintech VNF4/Ultra ZENITH VE Motherboard
Hi! Help me, please, I dont know how to connect front panel with connector on motheboard Chaintech 9BID1. I can't found motherboard User Manual... Thanks!
The pins should have markings on the MB saying which connector goes to what pin.
If not here's a diagram
Hope this helps
Dec 17, 2010 | Chaintech (9BID1) Motherboard
How to link case wires on the mother board? I've lost the manual and i don't find any stuff on chaintech website...
hi
  • Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.
  • Step 2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.
  • Step 3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.
  • Step 4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.
  • Step 5 Connect the power cable to the back of your computer, and turn the computer on.
  • Jun 30, 2010 | Chaintech 9PJL APOGEE Motherboard
    Hi. there is no sound on my pc after formatting. it says that there is no sound device or sound card. my sound card is integrated in motherboard. i think i need to install sound card drivers but i don't...
    heres the chaintech website http://www.motherboard.cz/chaintech.htm you will need to identify your motherboard model - should be written on the actual board and then download the soundcard drivers - you should also download the motherboard chipset drivers, they will have an impact on the performance
    you may be able to get the motherboard model by running www.belarc.com
    Mar 19, 2010 | Chaintech Computers & Internet
    Where do i go to update drivers & software for Chaintech 7NJS-ZENITH ULTRA Motherboard
    Here is the only i could found
    http://drivers.softpedia.com/downloadTag/Chaintech+7NJS+ZENITH
    Jan 11, 2010 | Chaintech 7NJS-ZENITH Ultra Motherboard
    PCI Slot 1 (PCI bus 1, device 10, function 0)
    Hi there,looks like your devices need updates to function correctly,
    from devices manager,
    select the device with the yellow question,
    right click and click on update
    even if you have no disk or internet
    let the wizard find the drivers automatically
    should be preinstalled with your OS XP
    go thru your list and update any other question marks in yellow.
    Should be able to update the network device on this system and then connect to the internet to finish anything else
    heres the link for the Chaintech motherboards
    http://www.download-device-drivers.com/Chaintech.php
    Hope this helps,Cheers Misterdj
    Jun 19, 2009 | Chaintech 9LIF7 i845G Motherboard
    Cannot install windows xp
    If your hard drive is NOT a SATA hard drive, try looking on the back side of the hard drive, and see if the jumper pins are set at "cable select". If they are not, this could be the problem. Once the pins are configured correctly, this should solve the problem.
    Apr 03, 2009 | Chaintech AMD (7VIF4) Motherboard
    Motherboard Chaintech 7NIL1
    maybe your motherboard is damaged so you have to find a computer technician to do a through check
    Dec 15, 2008 | Asrock 775i65GV Motherboard
    Manual?
    The connections are show between the last 2 PCI slots. The connector is CN1A.
    Here are the connections.
    1 & 2 = G Button
    3 & 4 = HDD Led + to pin 3
    3 & 9 = Power Led + to pin 9
    6 & 12 = Speaker + to pin 12
    11 & 13 = Power switch
    14 & 16 Reset switch
    17 & 18 = G Led + to pin 18
    15 is keyway [no pin]
    [2 4 6 8 10 12 14 16 18]
    [1 3 5 7 9 11 13 15 17 ]
    Sep 14, 2007 | Chaintech 7NJL3 Motherboard
    Asrock 775i65GV Motherboard Logo
    171 people viewed this question
    Top Asrock Computers & Internet Experts
    David
    David
    Computer Links
    pankaj rautela
    pankaj rautela
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
