Home | Philips | DVP5990 DVD Player | Can I connect a Eur...
Philips DVP5990 DVD Player
Problem for Philips DVP5990 DVD Player
Can I connect a European HP5990 to the US power grid?? 210V-110V
By www6 on Jul 03, 2009
Same problem here, potentially
I moved from Europe to the states.. It looks like I should not connect my EU HP5990 to 110V power..
Best Solution
posted on Jul 03, 2009
Very Helpful)
ACEA1
Rank: Apprentice
Rating: 100%, 1 votes
Many manufacturers design equipment with varying voltages in mind, and may list an ability to handle input ranging from 110-240 volts, indicating that it will work in Europe and the United States. In addition, the equipment is usually rated at 50/60 hertz, and will function on either cycle. However, some devices, especially hair dryers, are designed to function at either 110/60 or 220/50. If this is the case, a voltage converter is necessary.
If this is the case, look at the wattage requirement of the device, which should also be listed. When buying a voltage converter, be certain to get one with a wattage which has a higher rating than the device you are plugging in, to prevent electrical malfunction. Some electronics also require more energy at start up than in a running or standby mode, and if this is the case the wattage rating of the voltage converter should account for 120% or more of the listed wattage need of the device....Setanta
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Philips DVP5990 DVD Player
Questions and Unsolved Problems for Philips DVP5990 DVD Player
Do you recommend Philips DVP5990 DVD Player?
Answer
Answer
need a code for philips dvp5990 so i can use my sharp aquos remote
Answer
How do I play movies from an iPod through the USB connection on a Philips HDMI DVD player? When... (More)
Answer
small problem how do i shut off the little movie camera and 1/2, looks like a chapter display. it... (More)
Answer
it says no disc everytime a dvd is inserted, had already been watching same dvd many times before.
Answer
i need dvd codes for a philips dvd player
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips DVP5990 DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
