Question about Bestec Computers & Internet
Blinking green light on the power supply with no power
    Novelist:
  • 79 Answers
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you are the victim of a bad BIOS flash, don't freak there are some options. First off, if the computer (or motherboard) is still under warranty the Computer (or motherboard) can be sent to the Vendor for a BIOS reprogramming.
If you are a DIY PC builder and the warranty is expired you can take out the bios chip and sent it someone who reprograms BIOS chips or you can buy a brand new chip form them. I will show you my people.
http://myworld.ebay.com/***angelb***
or
http://stores.shop.ebay.com/Bios-Depot__W0QQ_armrsZ1
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4.Set the Cmos jumper to clear. Power up the pc. Power down the PC. Setthe Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6.Check the powersupply function. Either by a powersupply voltagechecker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a differentpowersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
Take out one of the RAM sticks if there is 2 or more. Swap the RAMsticks in different RAM slots. Try one stick at a time to see if youcan get the PC to boot. If this works, then the remaining ram sticksare damaged.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Brian
Posted on Jul 06, 2009
2 Suggested Answers
fwadley
  • 482 Answers
SOURCE: power supply light has blinking green light
If the power box is bad, The computer will not come on. if you only get a green light, you would need to start with replaceing the power box, if you get a new one and the same thing happens, then the mother board is bad too.
Posted on Nov 27, 2007
Vaio desktop blinking power supply
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector and next to a green blinking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
If the steps above don't work you will need to get a new power supply.
May 19, 2012 | Sony VAIO VGC-RB42G PC Desktop
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
When the computer is plugged there is a fast blinking green light and will not turn on
A fast blinking green light means the power supply is bad and will have to be replaced. Make sure you replace it with a least the same wattage supply that is in it now.
Hope this helps.
Feb 10, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
My vaio wont turn on and the green light in the back keeps blinki
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
Apr 28, 2010 | Sony VAIO VGC-RB53 PC Desktop
PC will not turn on blinking green light on power supply
The green light on power is blinking, it means power supply working in main power and the main supply not constant that time after constant the green light, then turn on the PC.
Thanks
Aug 13, 2009 | Intel SR1350-E Server Chassis...
Blingking light on my motherboard, no power.
Chances are your power supply and computer is fine! From other forums on this problem (which I also had), I've learned the following:
1. If you unplug the computer for a half hour or so (the blinking green light will gradually slow down and quit) and plug it back in, the situation will correct itself and the green light will be steady; however if this does not work,
2. a reset that works for a lot of people with the blinking light problem involves leaving the power supply plugged in and unplugging the power supply connection at the motherboard (it usually also has a blinking green LED) and plugging it back in. To read up on how to do this, Google "blinking green light on computer power supply" and read through some of the forums and you'll come on more specific instructions. Usually, you have to wade through everybody telling you to replace the power supply or your motherboard is fried. It's worth a try for a quick fix, just in case those situations don't apply!
May 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
I have a Compaq SR 1000 desktop set and I can't get the power to go on. When I plug the unit in a green light in the back keeps blinking. When I disconnect, hold in the power button the blinking stops, but...
Hello shapscomp
The blinking green light is likely your Ethernet card's LED. Is the blinking light located near your Ethernet (network) cable?
It sounds as though your power supply has failed. You may be able to purchase a replacement power supply for it.
Would you like some assistance in deterimining if that is the case?
Thank you
BJ
Apr 05, 2008 | Computers & Internet
Power supply light has blinking green light
Nov 26, 2007 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Computers & Internet Logo
243 people viewed this question
Top Bestec Computers & Internet Experts
Lawrence Oravetz
JonSnell Electronic
JonSnell Electronic
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
