Question about Dacor DMT2420 1200 Watts Microwave Oven
Seems to work fine does not heat up food - Dacor DMT2420 1200 Watts Microwave Oven
    Brigadier General:
  • 3,006 Answers
On every microwave oven which I've been asked to repair with the same symptoms, it's the magnetron which has failed. This is the bit which generates the microwaves and it fails more frequently on high wattage ovens.
If your oven is under warranty then send it for repair. If not, then you'll need to judge whether the repair estimate makes sense compared to a new oven.
DIY repairs are usually very straightforward if you can get the parts, usually just a straight job of unscrewing and reassembling. In addition to the magnetron (sometimes called a Klystron) you'll need a microwave gasket. Sometimes it's supplied with the magnetron, but it's a small wire mesh doughnut which fits around the neck of the magnetron and gets crushed into position as the screws are tightened. If you cannot get this part then do not attempt the repair as it is vital for safety. It must always be replaced whenever the magnetron is removed for any reason.
Posted on Jul 03, 2009
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: microwave does not heat food or liquid
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
WonderTech
  • 268 Answers
SOURCE: mw8992rd seems to be working fine except won't
This sounds like a bad magnetron that would have to be replaced. There is up to 2000 volts stored in a microwave, even when unplugged. For saftey reasons I would strongly suggest you have a qualified technician check it out.
Hope this helps.
Posted on Aug 24, 2009
Testimonial: "Thanks for the info! That pretty much matches the research I have done on the problem."
heatman101
  • 43501 Answers
SOURCE: microwave seems itis working fine but not heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 22, 2011
I have a Whirlpool GH5176XPS microwave and everything seems to work fine except that it does not heat anything. I have checked all the fuses and they are fine. Any suggestions?
The problem is more than likely a bad magnetron, "heats food" the other two considerations are the high voltage capacitor and diode.
Mar 31, 2011 | Whirlpool GH5176XPS Microwave Oven
Microwave seems itis working fine but not heating
Basic
heatman101
Nov 26, 2010 | Maytag MMV4205 Microwave Oven
LMV1680WW will not cook/heat food; everything else seems to work fine. Where to look/fine problem and can this be fixed or do I junked?
the magnetron is bad, if you can install a new one by yourself its worth it if not buy a new one
Feb 04, 2010 | Microwave Ovens
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Mw8992rd seems to be working fine except won't heat food. timer, touch pad, inside light, carousel all work fine. tried different times and power levels but still no heat.
Hope this helps.
Aug 24, 2009 | Emerson Microwave Ovens
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Microwave Ovens
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Doesn't Heat
replace magnetron, check highvoltage related circuit.
Nov 06, 2007 | Sunbeam SMW777 Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
359 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
