Question about Kenmore 73952 Gas Dryer
Newer kenmore dryer does not heat , element has continuity
4 yr old dryer does not heat there is continuity in the element .
what else can be wrong
  • 234 Answers
Check the thermal cut-off located on the heating housing. check for continuity on that.
Posted on Jul 08, 2009
My Kenmore electric dryer model 417.80412700 wont heat up but the element is still good. What else could be wrong?
Some dryers have a hi limit safety switch that is a one time fuse type switch . If the dryer gets too hot this switch opens and prevents the heating element from operating it is usually about 1/2" wide x 2" long plastic part with two wires attached to it.
You can test this part with a continuity tester. Unplug dryer, remove wires and test for continuity between the terminals. No continuity means the part needs to be replaced.
Hope this helps.
Bo
Jan 05, 2015 | Kenmore Dryers
Kenmore dryer not heating
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
Apr 28, 2012 | Kenmore Dryers
Kenmore electric dryer #11066512694 no heat & keeps running
Heat circuit also runs through timer and motor
Oct 26, 2017 | Kenmore Dryers
10 yr old kenmore dryer clean vents moves LOTS of air, no heat, element 12 ohms resistance, suspect thermostat or thermal cut out, how do I know which to replace?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 03, 2011 | Dryers
My 6 yr old Kenmore Elite dryer no longer heats up to dry clothes. It passes all diagnostics & thermister, moisture sensitivity circuit + all relays test ok. What would I look at next and if it's the...
I had a similar problem if it is a 220V dryer you may have tpipped a circuit or blown a fuse. The unit will tumble and circulate air still but the heatin element is controlled by the other circuit. Hope this helps..let me know Thanks!
Feb 16, 2011 | Kenmore Dryers
No heat in dryer. Vents are clear and clean. Just purchased this dryer 2nd hand. Unti is 3 years old. Could I have wired the plug wrong?
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpgCheck the continutity on the thermal fuses and replace the one that has no contiunity.
Feb 12, 2011 | Whirlpool Dryers
On a 3 yr old frigidaire elec. dryer witch is likely to go first the thermal fuse or the heating element.
It could be either. But I would check the element with a multimeter for continuity.
Nov 26, 2010 | Frigidaire Dryers
Dryer runs, but does not heat up
This can be a few things - and it is suggested they be tested before replacement.
1. Faulty heater element. (usually not likely in a newer machine - but possible)
2. Blown Thermal Limit Fuse. (most likely)
if you dried a large load - or heavy one last - it likely went over-temp and caused the thermal fuse to blow.
CLICK HERE and enter your full model # to see/order a new fuse after testing the continuity of the old one.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore electric dryer runs but no heat ....
Before I wish you luck i want you to review all of the possible reasons for your problem
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
May 29, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Kenmore 73952 Gas Dryer Logo
182 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
