Question about Panasonic KX-TG5632M Twin Cordless Phone
DURING AN ELECTRICAL STORM THIS PHONE QUIT. IT NOW WILL NOT SHOW ANY INFORMATRION ON THE BASE LCD. IS THERE ANYTHING I CAN DO TO CORRECT THIS?
  • 22 Answers
Protectiion diodes inside the handset are designed for this. Have you tried another charger/power supply since the power surge/spike? Battery may have also been reduced to 3.58 volt threshold or below. This will "not" allow the charge cycle to act in a normal mannor. If all that fails. Time for another. Capacitors don't like extrame power surges. nor do diodes or resistors. Says it all yeah
Posted on Jul 03, 2009
My display on my cordless/corded Phone won't light up. The cordless ones say out of range, or Searching. What can I do?
Is it the base display that won't light up? Can you make a call from the base? do you get a dial tone on the base?
Remove all batteries and unplug it all. Leave it sit for a few minutes. If that does not do anything, then it likely needs repair.
If the base makes a call, but cordless doesn't work, then likley the rf radio is damage by static from the storm.
Oct 04, 2014 | Motorola Mobility L702C DECT 6.0 Digital...
Insignia quit working after storm
Check the fuses on the power supply board first. They usually blow when you get a power surge. You may be able to replace them and get the TV running for a few dollars. If the fuses are good then the power supply board will be the issue. The main board should not be damaged because the surge has to go through the power supply board first.
Aug 22, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
Kdl40ex401
Hi there!
One of reasons your tv not working, the thunder storm /lighting possibility has burnt your Tv micro processor. get a technician to check the power supply section too because during the thunder storm your TV circuitry received excessive voltage .
If is the main processor is burnt you have to change it for the TV to work .
Jan 10, 2018 | Sony KDL-40EX401 42" HDTV-Ready LCD TV
Had a bad electrical storm. The next day my cordless AT & T phones ( 1 base with answering machine and 1 remote phone) had no dial tone. They both ring on incoming calls but unable to connect. They...
The damage is not to the phone line it is to the phones. Unfortunately this is very common with powered phones as they are almost never kept on surge protectors and are very fragile. You will need to purchase a new base station to use with existing phones.
Apr 29, 2011 | AT&T 650530003417 Cordless Phone
Why using a telephone during a lightning strom is dangerous?
Hi
Lightning routinely gets into copper telephone cables during storms and can overwhelm the fusing protectors at your home and enter a telephone set, causing a lot of immediate damage to the telephone and the user.
Lightning can travel from outside your home to inside your home—and to you—through materials that conduct electricity, including electrical wiring, phone lines, water, and plumbing. These safety guidelines will help minimize your risk.
If you need to use the phone corded phones are dangerous during thunderstorms. Lightning traveling through the telephone wires has killed people. Cell phone and cordless phones are a safer choice, but stand away from the cell or cordless phone's power base
Hope this will help you.
Mar 18, 2010 | Lands Phones
Nothing shows up in the display. This has only been recently after a power glitch. The display lights when a call is made or received.
I unplugged the base unit from the wall for more than 10 minutes. Sometime after I plugged it back in (not immediately)the display re-appeared.
Nov 16, 2009 | Panasonic KX-TG2631 Cordless Phone
Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Jun 15, 2008 | Lands Phones
GE 25931 Cordless Unavailable
I had the same problem recently due to a power outage during a storm. GE advised to disconnect the power cord and telephone cord on the "mother" unit. Wait five minutes. Then plug it back in.
I placed the "mother" phone back in the base. After the screen flashed on the "mother" phone, I removed it and then put the other two portables in the "mother" base.
This corrected my problem and all is now well.
Jul 31, 2006 | GE 25931EE1 Phone
Panasonic KX-TG5632M Twin Cordless Phone Logo
151 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
