The unit appears to work but when the power is turned on the display and the interior light dims and the unit appears to not be working at full power.
SOURCE: 2001 pontiac sunfire wont start
I have had the exact same problem. There is an ignition lock that probably went off. There is a fuse box under the hood. The fuse that says ignition on it pull it out and put it back in. This should reset the ignition lock. Its a safety feature because the car thinks that someone was trying to tamper with it.
SOURCE: Passenger door light remains on; all interior lights remain on
is yiur batery in your key ok?
SOURCE: Dim interior lights, power locks wont work......
Try looking at your battery. Check the cables to make sure they are tight and clean. Brush the corrosion off with a wire brush. Now, if you have a wiring schematic, find the ground for the interior lights and clean it up too. Oh, put vasoline on it, and the battery cables, to keep them corrosion free. Check the other grounds in the car cabin too.
SOURCE: 04JeepGrdCher:Interior lights stay on and power windows dont work
I had this same problem but no sunroof on mine. there is a bundle of wires that goes into the door and if the power wire breaks and the power window lockout was pushed when it happens no windows work and the dome lights stay on on mine it happened on the drivers side it was an easy fix i took the door panel off and unpluged the harnes and pulled it through the inside of the jeep and spliced the wire back together and it has been working since.
SOURCE: brake lamp light on a 2002 Honda Accord SE
I assume you mean the one on the dash. This is an indicator that there is a problem in your braking system. Make sure it's not low on Brake fluid and have the brake system checked or check it yourself. If your going to check it yourself I recommend the Haynes repair manual on your vehicle as a reference.
Hello Arold - Typically, error code SE indicates a shorted keypad. Try resetting the microwave by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the touch keypad on the unit will need replacing.
