How to connect two monitors with one system unit
I bought two monitors with one P4 celeron mother board. It has 2 USB ports.two keyboards and mouses also were purchased. I Iwant to know how to connect them so that both monitors can be used independently.
  • sukumi Nov 12, 2007
    Indeed a positve and practical helpful answer was provided. Now I am thinking to connect more than two monitors. Yes, possibly Celeron processors capability to support such enhancemnt needs a fresh review. thanks.probably I need to be regular in perusing your site for more workable help.
  • fahizan Dec 14, 2007
I want to connect 1 system 2keyboard 2 mouse 2monitor
Posted on May 24, 2008
  • 71 Answers
You will need a video card that has more than 1 head ( output ports), and a software program that will let you do this with windows can be found here or here.
Posted on Nov 10, 2007
Keyboardunlock functions
if your keyboard is a USB connect that you have to set USB ports enable on boot from mother board Bios setup.
if not try another keyboard.
if connected to Keyboard, Video Graphic card, Mouse (KVM) switch better to check the connection if every thing is right.
boot the system and monitor the caps luck,numluck, light for flashing ones in during boot. if light flashes ones so extend wait time to let the drivers be loaded.
Feb 12, 2012 | NEC Versa LX Notebook
My computer seems to boot up fine but my monitor says no signal and my keyboard doesnt work
You can try tighten up the cable behind the monitor or disconnect the cables and reconnect. You can try another monitor to see whether the mother board and the cable works. Some settings in BIOS may be changed to use on-board video card (the one embeded on the mother board, which is connected on the ports out of the card slots) on your computer so make sure it is using the graphic card that is connected to the monitor. For keyboard, if may be mechanic issue on port or keys or cables if you will not see anything wrong about the keyboard. You can try to use another USB port if it is an USB keyboard or use a USB/PS2 converter if the PS2 keyboard port is not working. If it is a PS2 keyboard, you can check whether the pins are bent and reconnect it. Sometimes that helps. If it is a wireless keyboard, then you will need to fix the monitor and then maybe fix the driver and stuff. You can remove all objects beneath the keys by putting it upside down and shake it or use a blower.
Jan 05, 2011 | Computers & Internet
I have a wireless keyboard and mouse and I can't type anything I changed the batteries and its acting like it has no power, nothing is working on the key board but the mouse is working. Thanks Tate
1) make sure your batteries are inserted correctly
2) make sure when you insert the USB sending unit into a port that the USB port is working
3) press the connect button on the sending unit and also the connect buttons on the bottom of the keyboard and mouse.
3) make sure in the system setup that USB is enabled.
var fctb_tool=null; function FCTB_Init_7207035e866d4ce295e256df09c8897a(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_9fd4111ba11a4016a30810809c03e786(t) { fctb_tool=t; start(fctb_tool); }
Dec 18, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Usb mouse and keyboard no longer work; monitor does
if they are wireless it might be a driver problem but if there just usb then the mother board might have failed. are you getting keyboard not detected errors.
May 15, 2010 | Trendware TK-207K 2-port USB KVM Switch
Can i use 2.8ghz cpu for my p4s533-e?
this is what asus says:
arrow-org.gif Latest P4 CPU Support
The latest P4S533-E motherboard supports Socket 478 Intel® P4 processors, which utilize the most advanced 0.13um process technology to provide frequencies up to 2.53GHz
Mar 23, 2010 | ASUS P4S533-E Motherboard
I bought two monitors with one P4 intel mother board. I want to buy one VGA switch two keyboards and two mouses. I want to use one pc for two monitors two keyboards and two mouses at the same time. is this...
Yes, this is possible. You will need to purchase a device similar to a KVM switch. You can check out Best Buy or to an electronic store like Radio Shack.
Dec 06, 2009 | Dell E173FP 17" LCD Monitor
My keyboard, mouse and USB ports do not function at Startup any more. The keyboard and mouse function perfectly on other machines. The motherboard is ASRock P4i45GV (5.0), with a Celeron. I've used the...
Are the mouse and Keyboard USB varieties? If so, then try plugging in a PS/2 mouse and keyboard and boot the machine up. You can then check your system hardware settings in control panel and reinstall the USB drivers. This would be my first step in solving the problem. If you need any more help then just ask
Nov 11, 2009 | Asrock P4I45GV R5 Motherboard
My computer is not working shows keyboard erro and stop
When you monitor saying which is no signal this is a monitor port problem. Check your monitor connector if it is properly connceted to the motherboard. That is the only way of monitor saying no signal.
Aug 22, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Keyboard not functioning
usb mouse and keyboard depend on ur usb ports and ur bios u should check that ur usb drivers are installed properly or not .n try changing ur keyboard in different usb port . thanks
Feb 24, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    Jun 30, 2008 | IBM NetVista PC Desktop
    Computers & Internet Logo
    1,168 people viewed this question
    David Payne
    David Payne
