Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel lines routing
My chain saw engine feul lines are defective and I need a picture of the routing of the lines
  • 3 Answers
SOURCE: fuel lines
Line into tank isn't easy to pass. I made small hole in line near bottom, tied 30 pound fishing line to it (with knot inside of tube lumen), passed line through opening from above, and with fishing line pressure pulling gas line in, I squeezed tip of gas line entering tank from above with needle nose pliers until the line went into tank. Then i pulled excess through until i could trim tip (with knot) through gas tank opening, and then reversed line pull back into tank. Trim other end to fit onto primer exit port.
Posted on May 04, 2009
dontbother10
  • 2220 Answers
SOURCE: installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Posted on Sep 14, 2009
dontbother10
  • 2220 Answers
SOURCE: fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Posted on Oct 24, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Polan Model 2375 Wild Thing Chain Saw.
A Poulan IPL for your saw “2375LE Gas Saw Type?” (LE is code for WildThing; if your saw is beyond serial -2 look at a saw without the LE; it makes little difference to the fuel system) can be found here:
Poulan.com
The dash number of your serial number is the type.
  • Small hose (filter on bottom) long enough to reach all corners inside tank, to lower carburetor connection. Please leave the 2 carburetor connections long enough to reverse until the saw is running.
  • Upper carburetor connection, small hose to suction side of primer.
  • Pressure side of primer (large hose) to tank fitting.
The IPL is deceptive it appears the filtered hose connects to the primer; it does not.
A typical fuel system and suggestion or 2 follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 20, 2010
Testimonial: "Thank you for your help. Your instructions were correct.I did have to reverse the connections on the carburetor. My chainsaw works fine now."
  • 4088 Answers
SOURCE: fuel line replacement on Poulon 2050 14 inch Gas Chain Saw
First rule is to replace only one line at a time. Needle nose pliers is the only tool you should need. Replace the fuel line from the filter in the tank to the carburetor by removing the filter from the line, extract the line out of the tank, and remove the other end from the carburetor. Use the old line to measure for the replacement. Measure the point where the old line passed through the tank wall down to the filter connection. Mark this point on the new line, and push the line into the tank far enough to attach the filter (which you have checked for plugging), then pull the line back out to the mark. Make sure that you use the proper line for this connection as the filter must flop around to the lowest tank level so that the saw doesn't run dry of fuel when operated on it's side. The other connections are straight forward--just replace one at a time. Don't be stingy in making looping turns as you don't want future kinks. Hope this helps!
Posted on May 02, 2010
Testimonial: "I'll give the needle nose pliers another go at it! Problem is, the pliers aren't able to pass into the neck of the fuel tank from my last attempt."
Why does the engine only run at full choke?
You're not telling us anything about its history or other symptoms. Given that, it's got fuel delivery problems, to possibly include: clogged fuel filter, cracked or collapsed fuel line, leaking purge bulb, clogged carb screen, stiff or leaking carb diaphragm or loose carb mt bolts, for starters. Replace lines, bulb & filter & rebuild carb first, in that order. Pay close attention to fuel line routing- take pix. You'll need a special tool to adjust carb mixture- Husqy carb tool
Jul 08, 2014 | Poulan Pro Chain Saw 46cc 20"
Need routing gas line
You can't........your using an electric chain saw !
Jun 25, 2014 | McCulloch 10" Electric Pole / Chain Saw
Fuel lines on craftsman chain saw
go to the website and see if you can download a manual
most saws have 2 lines fuel in and a return
the fuel in line is the one that goes in the tank and has a filter on it
hold you finger over the fuel line on carb and pull cord, the one that sucks is your fuel in, the one that blows air out is your return
Mar 07, 2014 | Craftsman 42cc 18" Gas Chain Saw
Need to replace fuel lines that is rotten
Hi randy waldrop...
Here is the fuel routing for chain saws
Please rate me
Bud
Sep 29, 2012 | Craftsman Sears Chain Saw Manuals Model...
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
May 07, 2010 | Poulan ES350 16" Chain Saw
Fuel line routing
A typical fuel system and a couple of suggestions follow:
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
If not your saw, yours can be found here:
Poulan.com
I am reasonably sure the upper most carburetor connection (it bleeds any air in the carburetor, air rises) goes to the primer. Leave the hoses long enough to swap them and try it. They can be shortened once you verify the correct routing. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro Chain Saw 46cc 20"
1997 ford f-150 starts then backfires thru intake and then shuts off.
most likely the feul pump. test the feul pressure with a gauge. look of ther little metal feul line on the intale manifold. tst pressure. have freind listen at the rear of the truck for the pump prime. key on only. then start the truck, friend should hear pump running. could also need a timming chain but pump is more tlikely
Dec 27, 2009 | Ford F-150 Cars & Trucks
ZAMA carb fitted to Makita chain saw which way
Hello Gordon; We need the complete make, model, and serial numbers with every question in order to fully help you. The IPL for the DCS510-18 can be found on this page: http://www.makita.ca/index2.php?event=tool&id=361&catid=40 Fuel line routing2.gif while pictured isn't clear. In the US of A these are red and called Dolmars. A local dealer may allow you to look at his shop manual if one exists. Sorry to not be helpful. Lou
You must help us if we are to help you!
Sep 11, 2009 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
I have a 3516 chain saw mod22-600035-18 Mcculloch the fuel lines
I wish I could help. There are no parts available, there are no Exploded parts lists I've found a link to. These are Chinese chainsaws with the McCulloch name. They ARE Chinese chainsaws and I'm disappointed in Mac. Most mechanics won't touch them. We can provide no more help with this saw. Sorry
Lou
Poulan or Craftsman gasoline chainsaws are reasonably inexpensive, parts are available, and given a little TLC perform well.
Jun 10, 2009 | McCulloch Garden
Fuel filter replacemfnt on husky chainsaw model 345
the feul filter will be in the tank disconnect feul line from carb and access through filler cap you will need a pair of long nose pliers remove through the tank
Apr 05, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
201 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
