Question about Philips 9P5034C 50" Rear Projection Television
No picture pic gets big then small and color is red and mixed the tv is a 50"phillips/magnavox projection model 9p5034c103 thanks i was told it was a chip of some sort please help.
    Scholar:
  • 150 Answers
Hi, common problem, have a tech replace IC7412, gl, video-tek
Posted on Jul 03, 2009
My phillips mangnavox 9p5034c103 the picture is only orange color i 'cant adjust the other colors?
The fluid in the lenses needs to be repalced. This is common. You can get parts and repair instructions from http://www.TvRepairKits.com
Feb 23, 2011 | Philips Magnavox 51MP392H Rear Projection...
Model number#55P8288A Phillips Magnavox(PVT910)We have no owners manual.And the picture is too orange.where can we get a manual to set it right
http://www.tvrepairkits.com/download-guides/tv-kit-001-002.pdf
www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual
www.scribd.com/.../Philips-Training-Manual-TV-Plasma-Display-Panel-Chasis-FTV1-9 -
Service & Repair manuals for your unit.
Sounds like your set has developed a "Color Mixing" problem, Please use the troubleshooting procedures and you will soon be able to find out what to do.
Apr 29, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture is going out
it is either ic 7411,7412, 7413 they are cheap replace all three, they are located on the back of the large signal panel right in the middle, very common issue. If you can't solder the repair may cost around 200 or so .
Sep 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
MAGNAVOX PROJECTION TV- GOOD PICTURE , BUT NO COLOR
you need the ssm panel. You can get a replacement panel for your model at the following link.Which is the correct board for your model it controls color, convergence and etc.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-ptv900-series-ssm/cName/sale-items
Apr 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
My 60inc phillips magnovox has poor color, what do i have to do?
we just bought a 55 inch phillips magnavox and told it was working fine when we got it home and turned it on it was a red screen and was really foggy. we looked up some tv repair places and ONLY 1 told us it was the picture tube and to look down them with a flashlight for bacteria! sure enough the green and blue had it. so we found one place that would sell us the coolant fluid that you have to change the others could get it in or wanted us to bring the tv to them. we did it our selves the stuff was $17.00 a bottle or if we took it in it would be about $375.00. we have a great picture now and it wasn't as hard as all the other repair places said.
Dec 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture problem
I had the same exact same problem. You can get a repair kit from this site. http:///www.magnavoxhelp.com
Aug 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
can you post a picture of your screen or send it to my email slinteriors@yahoo.com as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Jun 28, 2008 | Philips 55PP9363 55" Rear Projection...
Blury picture, convergance problem
What you're describing is probably contaminated coolant in the crts. Between the outer part of the crt and the lens is a chamber filled with a coolant (ethyl-glycol) which can become contaminated and cause blurred picture. I'd strongly recommend taking this to a shop the procedure for changing these is a bit beyond the layman level.
Remove Crt assembly. Mark the Crt lens position for accurate reasssembly.
Mark the centering ring's postions to make easier realignment and carefully remove lens assembly by removing the four torx screws. Keep Crt assembly vertical so you won't leak the fluid...
Remove the inner lens by carefully prying up on the edge of it.
Dump out the fluid in the sink and wash the face of the Crt and chamber with water to remove all the fungus and crud. Flush the chamber with isopropyl alcohol to kill all the fungus and dry thoroughly.
Reassemble inner lens and outer lens and tighten all four torx screws.
Remove side filler plug and fill chamber with approved new Crt coolant, reinstall and converge.
Repeat this procedure for the other two Crts. It will need this done whether it looks clear or not !! The green and blue Crts in this unit are prone to this failure.
Hope this helps
Bill
Nov 14, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 9P5034C 50" Rear Projection Television Logo
365 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
